03-19-2008, 07:16 PM
#1
Vehicle: Citroen Xsara 2,0 16V VTS
LS-372 CPU Support
Does anyone know if other cpu's than T7100-7700 & L7500 are supported by the 965 Chipset on the LS-372 Motherboard from Commell ?
http://www.commell.com.tw/Product/SBC/LS-372.HTM
I have my LV-677DC Mini-ITX but i would like to do a new carpc with the ls-372 in the dash, and reuse the T2400 i have in my "old" mobo, to begin with.
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
03-25-2008, 10:11 AM
#2
Just got a reply from commell, it seems that Cel 550 will be supported.
Q:I am wondering if there is support for some of the older Core Duo mobile cpus, or only the T7100-7700 & L7700 ? I was thinking of using maybe a Celeron 440 or an older Core Duo T2400 CPU, will this be possible, maybe you could send a list of supported cpus ?
A:Not support T2400,
Support Celeron 550 for Intel GME965 chipset, refer website below:
http://download.intel.com/design/int...hts/319219.pdf
Q:I would like to know if there is support for 800mhz memory modules ?
A:YES
Q:How about the HDMI interface, does it also carry audio information, or is it only the DVI signal that is sent using HDMI ?
A:It's only the DVI signal.
Q:Will there be a Wide voltage version available at some point, like the LS-371 ad LV-677DC ?
A:Only 12V DC input.
04-14-2008, 10:38 PM
#3
Vehicle: 2006 Evo MR
That is good info. Commell hasn't responded to any of my emails.
I didn't know it could use 800MHz RAM...maybe I will upgrade.
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 100%
Installation/Fab/Assembly (Revised):
[----------] 80%
04-15-2008, 10:39 AM
#4
I wasn't able to find 800mhz SO-DIMM's here in denmark locally, but i must also admit that i wanted to be sure it would work, and since 800mhz is not listed in the specs i stayed with 667mhz instead.
04-15-2008, 01:06 PM
#5
I don't know if these guys ship internationally, but 26.99 USD after rebate is pretty cheap for 2GB 800MHz
http://www.newegg.com/Product/Produc...82E16820227250
Planning:
[----------] 100%
Purchasing:
[----------] 100%
[----------] 80%
04-15-2008, 02:02 PM
#6
Thats a nice price, usually though shipping makes it more expensive than what i could find it locally for, i have not actually looked that hard, i could probably find it here also.
04-15-2008, 08:29 PM
#7
Vehicle: Ford F6 Tornado UTE
Hey Dope,
The LS372 will accept pretty much most Socket-P processors, which is the same as those used on the new laptops with Santa Rosa chipset (965)
The older 945 chipset supported Core Duo (Yonah), Core 2 Duo (Merom) processors on the Socket-M boards.
The pincount on both these processors are the same, but, there's one index-pin placed differently between the two socket-types, so they can't be used across the 2 platforms.
So basically the new Core 2 Duos will be T7100/T7300/T7500 etc, and the celeron variants, whereas the older ones will be T7200-T7800 and celeron variants.
Hoppe this helps a little
04-16-2008, 03:03 AM
#8
Thanks, i already got a T7500 though :-) but good as a refence post i think, since the material on this board is very limited.
| Thread Tools |
| Display Modes |
Linear Mode
