The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-22-2008, 11:29 AM   #1
My Photos: (0)
Advice on how to mount screen on / in this dash
Below is a pic of my cars dash. I have a nice 8 inch touchscreen monitor I want to add right in the middle where the old radio and empty socket currently are but the monitor is too big.
I`ve checked the screen and if I can find a way of mounting the monitor on a stand that would fit at the bottom of the empty space it would not obscure my existing switches such as hazard lights etcetera so would not fail an MOT.
However I am unsure of how to mount it there, any advice would be appreciated as its the best place to have it in my car (2001 Kia Shuma 1.6). I`m thinking maybe clamping a homemade stand in somehow at the moment but maybe someone here has had this issue and found a good way of solving it?
The gap available is 9.8 cm high and 9 cm wide, I wonder if there is a simple way to attach some sort of stand perhaps?
mentalmummy is offline   Reply With Quote
Sponsored Links
Old 03-25-2008, 03:45 PM   #2
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (231)
Maybe you should change the screen to a 7 inch..... i had two 9 inch visors, but they were composite (bad for a PC), so i threw away the screens but kept the casing and the EBY701s' fit perfectly. Im sure if you take them out of the case, they will fit in that space.......
PLANNING [50%]
CAR PC ITEMS [75%]
INSTALL OF PC [80%]
INTERIOR MODS [35%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 03-26-2008, 08:13 AM   #3
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
If you don't mind not having the monitor permanently mounted in the dash, then why not just attach a rectangular piece of material shaped to fit in the cubby below the radio to the back of the screen, and then slide the mounting block combo into the cubby. A bit of foam tape or adhesive rubber strips on the mounting block would ensure a tight, stable fit. I think that would be far easier/less expensive/better looking than a separate stand with the screen mounted to it...and would have the additional benefit of being more stable if you are using a touchscreen.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 03-27-2008, 10:02 AM   #4
My Photos: (0)
That would make sense as I don`t really wish to remove te screen from the casing if I can help it. Any recommendations for a suitable material?
It would be easier than changing to a smaller screen as am on a tight budget so this would be a great solution!
Sponsored Links
vB code is On
Trackbacks are Off
2007 Mazda 3 Dash Screen looks OEM Splash-X Show off your project 52 07-07-2008 06:13 AM
Dash Mount touch screen with DVD player XCESIV LCD/Display 1 10-18-2007 06:07 AM
Need touch screen advice sciff5 LCD/Display 0 05-29-2005 09:58 PM
in dash touch screen in Vaux Corsa (UK) m2rv h Show off your project 24 09-06-2004 08:57 AM
7-in in dash screen question traitorhound LCD/Display 7 04-07-2003 07:42 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
