it won't detect my ps2 ports on startup, Keyboard error... help!
Hi all,
ive just been in the process of seeting up the follwoing:
Jetway J7F2 2GHz C7 CN700 Mainboard
VIA C7 2Ghz CPU
VIA CN700 + 8237RP
Front Side Bus: 400/533 MHz
Graphic Interface: integrated VIA S3 UniChrome Pro AGP graphics
1 x 240-pin DDR2 Module Sockets Support Max 1GB
Audio: Onboard 6-Channel CODEC Compliant to AC 97'
On Board 1394a Port
On Board USB 2.0: 3 x USB headers (support up to 6 x USB 2.0 ports)
Back Panel I/O: 2 x USB 2.0 ports
Serial ATA: 2 SATA connectors
TV-out (PAL / NTSC): VIA VT1622A TV encoder
Expansion Slot: 1xPCI Slot (PCI 2.2)
VT6103 10/100 Ethernet
Dimensions : 170x170mm
RoHS compliant
VoomPC-2 Automotive PC Enclosure
M2-ATX - 160W Intelligent Car PSU
Kingston 1GB 533MHz DDR2
Seagate Momentus 5400.3 160GB 8MB Cache - ST9160821A
Sony NEC Optiarc AD-7630A Slot Loading DVDRW Drive
ive never setup a carpc but have done plenty of home PC's in my time. On booting the system up it worked fine until it states Keyboard Error when checking for the PS2 periphrals after the memory count.
For some reason i can not put my finger on why it will not detect my PS2 port, ive treid several keyboards and still nothing...
Im wondering if the motherboards PS2 ports is buggered for some reason - can't see it though as its all brand new from LinITX.
Any help or sugestions would be great!
Thanks in advance
