The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-27-2008, 06:48 AM   #1
My Photos: (0)
Hard drive failure
Hi all,
I mentioned having to keep renewing my hard drives on here a couple of months ago as for some reason after a little while (about a month or two) of working fine, they just start stuttering the music, and half way through a track it sounds like a scratched record, repeating the same second of music time after time.
My software is centrafuse, and everything seems ok, but i cant think it be anything other than the HDD.
I've tried sata and IDE, both happened.
I've also tried doing a system restore point, and also a disk cleanup and a defrag, no problems with the disk at all???
Unless anyone has any other ideas i thought about trying the O/S install on a 4gb sd card. Will this be slow running through a usb sd card reader? will it write the O/S to 4gb storage?
Would my best bet be norton ghost and rebuilding the o/s onto the sd card??
astrapc is offline   Reply With Quote
Sponsored Links
Old 03-27-2008, 08:07 AM   #2
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
if u've had several drives fail you might wanna reconsider the current layout of your install. How's the drive mounted? is it in a metal case? Near any magnets? More details would help.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 03-27-2008, 08:32 AM   #3
ThunderStick's CarPC Specs
ThunderStick's Avatar
Vehicle: 1986 Jaguar XJS
My Photos: (2)
Do you have a pick up or a vehicle with stiffer suspension?
Obviously shock on a Hard drive is really bad. Consider moving you computer to the center of your car. Like under you driver seat. This is usually an Ideal spot, since it will be in your climate controlled cabin of the car and normally the spot that shakes and has the least impacts when hitting those annoying bumps in the road.
Just a thought... maybe I am wrong.
To answer your question on the SD idea, ditch it. SD is super slow, go with a Compact flash card or a Solid State Hard Drive if you really think this is your last resort.
86 Jaguar XJS - Completed
New Age - RR Skin
Concept - RR SKIN
"Your two cents are worthless pennies if you consider the exchange rate for my 2 cents"
ThunderStick is offline   Reply With Quote
Old 03-27-2008, 09:27 AM   #4
FLAC is for flacid
parksgm's CarPC Specs
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Quote: Originally Posted by astrapc View Post
Hi all,
Are you sure this is hard drive related? I don't know that a song "skipping" could really be caused by a hard drive read error. Typically, a music program will read an entire mp3 into memory on a single read from the hard drive, and then play the song entirely from memory...it's not like the drive is continually reading the disk as the song is played (so, not like a record or CD player). Furthermore, even if you were receiving bad data from the hard drive, or difficulty accessing some part of the disk, I think that the music player would simply reach the end of the available data and then stop playing...not repeat playing a small fraction of the data that it already has in memory.
I'd investigate other causes first, especially since the drive checks out diagnostically. The sort of damage caused when a drive fails due to shock typically would show up on a full diagnostic of the drive, if it's severe enough to cause interruption of data reads. So, some questions:
  • does this happen on a particular mp3/set of mp3s/mp3s from a particular encoder?
  • when it does happen, can you skip to another mp3 successfully?
  • does the OS or any software you're running crash when or shortly after the mp3 skips?
  • can you replicate the skip by driving over the same section of road, at the same speed, that originally caused the skip?
  • when replacing your hard drives, are you doing a fresh install of all components, or are you ghosting an older drive image to the new drive?
Good luck.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 03-27-2008, 09:46 AM   #5
Banned
My Photos: (0)
Seen this before, have you installed the phoco option in CF? That might be just taking 100% of CPU process and making your music skip. Check your CPU usage when this is happening.
wjc04wrx is offline   Reply With Quote
Old 03-27-2008, 12:01 PM   #6
the_crooked_toe's Avatar
Vehicle: 2003 Mercedes C230
My Photos: (45)
i had skipping problems in my car at one point to. It actually boiled down to the WiFi periodically looking for a connection (when it doesn't have a connection). I disabled my WiFi connection and no more skipping! I turn my WiFi on when I need to connect it to the internet. I have a shortcut on the desktop to My Network Connections to enable and disable the device with ease
the_crooked_toe is offline   Reply With Quote
Old 03-27-2008, 01:48 PM   #7
Admin. Don't bug or I'll byte.
Bugbyte's CarPC Specs
Bugbyte's Avatar
Vehicle: 2001 VW Beetle
My Photos: (19)
I had the same problem, too. Turned out to be the Wifi card. The drive usually just fails and it affects more than just the music. Usually you get to where you can't reboot at all.
-Where in the world is the iBug?
-Find out about theiBug
-Attention Newbies! Have you seen the FAQ Emporium?
-No time to figure it out? Take 5 minutes to view the Car PC 101 video
Bugbyte is offline   Reply With Quote
Old 03-31-2008, 03:40 AM   #8
My Photos: (0)
Just wanted to confirm, it was the phonecontrol application that was causing the problem...and with centrafuse soon to be releasing a new phone technology, hopefully this will resolve the problem.
I removed the phonecontrol app, and it all worked fine again. very weird how it worked fine for over a month then crashed out and went fuzzy. Either way. At least this has saved me keep buying a new hard drive. thanks guys!
Old 03-31-2008, 11:07 AM   #9
FLAC is for flacid
parksgm's Avatar
Vehicle: Mustang GT
My Photos: (4)
Congratulations.
Old 03-31-2008, 04:34 PM   #10
My Photos: (0)
astrapc,
I am coming in a bit late and parkgsm went through everything I would have said in regards to diagnosing the problem further as it sounded like something other than the HD. He even said it more clearly and eloquently than I could have ever managed.
One thing I will note however is that CF and SD are not good mediums for OSs which can not be mounted read only. I have myself killed and seen many CF cards die as a result of such usage. You can get IDE to CF and IDE to CF to SD adapters so you can bypass USB altogether, however if your OS is going to be doing much writing you will likely have a high rate of failure in your cards.
SSD is likely too costly to consider at the moment, at least it is for me. Places like Logicsupply do sell industrial CF/IDEFlash solutions but HDs seem to be prevalent and cheap enough that you could stick with them until you had to find a different solution.
Cheers,
orGSD
orgsd is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Hard Drive Issues in a Vehicle Computer DarquePervert The FAQ Emporium 25 02-23-2008 01:35 PM
Hard drive dilema.... 2.5" or 3.5"? 3Tripnip General Hardware Discussion 2 01-14-2006 12:30 AM
Help!!! laptop hard drive ashbosh General Hardware Discussion 9 07-15-2005 01:34 PM
Laptop Hard Drive in carputer... Powers Newbie 7 05-08-2004 10:37 PM
How does a hard drive just die? Sleeka General Hardware Discussion 10 08-08-2002 02:27 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
