Quote: Originally Posted by
grandimperial
Which bit is the potentionometer?
Cos ihave pulled of the knob and the clear bottom and put them back together and it still works fine.
Its getting the cylinder shaped circuit board out of the lower angled piece of the housing.
Does the circuit board push out the bottomor top of this part?
IIRC, the beveled aluminum ring at the base of the unit is a separate piece from the barrel-shaped main body of the Powermate. I believe that those two pieces are also press fit, and perhaps held in place by a bit of silicon as well. You have to separate the barrel from the beveled base because the USB cable is soldered to the mainboard, and the USB cable runs between those two pieces.
