The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 03-31-2008, 01:51 PM   #1
My Photos: (0)
AMD Sempron 2100+ with TDP of 9W
Has anyone used the AMD Sempron 2100+ (fanless) with a TDP of 9W (Socket S1) processor ? [Press Release / PDF]
I have found two designations for it:
- SDC2100HAX3CM on CPU-world
- SMF2100HAX3DQE on Wikipedia
It runs at 1000Mhz, has 128KB L1 cache and 256KB L2, and most interestingly has a TDP of 9W and is designed for passive cooling although active wouldn't be out of the question.
Basic searching has revealed a price of just under $100USD but I havent found anywhere which actually has it in stock, nor have I found any place which has tested or reviewed it.
Has anyone here had a chance to play with it or know anything more about it than AMD's press release, the Wikipedia page or CPU-World page on it ?
Cheers,
orGSD
Last edited by orgsd : 04-02-2008 at 11:02 AM. Reason: Added links now that moderation is through
orgsd is offline   Reply With Quote
Sponsored Links
Old 04-01-2008, 10:58 PM   #2
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
I have an AMD Geode Socket A 14 watt processor that runs at 1.4 Ghz, 266 fsb. With a single 80mm 5 volt fan blowing in it, it never goes above 29C.
crooper is offline   Reply With Quote
Old 04-02-2008, 10:47 AM   #3
My Photos: (0)
Is that single fan simply in the case/enclosure or is it attached to the heatsink proper? If the former, do you have a "standard" passive heatsink with lots of fins, or is it something special?
Thank you for sharing your experience!
Cheers,
orGSD
Sponsored Links
vB code is On
Trackbacks are Off
IEI KINO-690S1 AMD Turion 64 Mini-ITX Mainboard HiJackZX1 General Hardware Discussion 51 05-09-2008 03:49 PM
FS: AMD Athlon 64 3000+ and 3700+ CPU's james33440 Classified Archive 4 09-14-2006 07:55 PM
AMD sempron - Mobo combination+M2-ATX Nomader Power Supplies 5 04-28-2006 03:58 PM
amd sempron 2400+ syfenx General Hardware Discussion 0 01-17-2005 03:23 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
