Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-02-2008, 08:36 PM   #1
treetop777's Avatar
Rear camera vs. car 12v
Can i hook-up this camera to the car's 12v ? Maybe to the M2-ATX better? It's 12v DC, 50mA max. http://www.dealextreme.com/details.dx/sku.5891
Thanks for any response.
treetop777 is offline   Reply With Quote
Old 04-02-2008, 08:55 PM   #2
FLAC is for flaccid
parksgm's Avatar
Better to hook it to a regulated 12V power supply, like the M2, or any other regulated 12V source. The car's voltage varies quite a bit below 12V when cranking, and quite a bit above 12V when running. Depending on the tolerance of the device and the surges, the device could be damaged.
Of note, the comments below the linked description seem to indicate that the camera does not have a very wide field of view and might not be suitable for a back up camera. Food for thought.
Good luck.
An amateur built the Ark. The Titanic was built by professionals.
parksgm is offline   Reply With Quote
Old 04-02-2008, 08:58 PM   #3
I just answered similar questions about powering a backup camera in another post -- search for it, don't have it handy.
Yes, you can hook that camera up to either your 12v from the car, or the m2-atx. Actually, you have three options:
- Car 12v accessory - camera will be on when the car is on
- Car 12v backup light 12v - camera will be on when you switch to reverse
- m2-atx - camera will be on when you have the m2-atx on
*Technically*, the m2-atx will be the best 12v source, since it's regulated. However, backup cameras are designed to hook directly into the car electrical system, so unless you have a huge spike then its fine.
You will either need to cut off the red plug and hardware the 12 volt and ground wires to the camera, or buy a barrel plug that fits into the red plug on the camera.
Honestly, though... I would look for a different camera. THat is a CMOS camera, and you won't have the greatest image. Look for a CCD camera instead.
NotYou is offline   Reply With Quote
Old 04-02-2008, 09:14 PM   #4
treetop777's Avatar
Understood. Thanks for the responses. Back to the drawing board..or maybe not..it's for my wife's car..she won't know the difference! LOL
Old 04-02-2008, 09:28 PM   #5
FLAC is for flaccid
parksgm's Avatar
Make sure the camera is designed as a backup camera, and the above is likely true. Also, you could hook it up to the M2 for power, and switch the power on with a relay connected to your reverse lights.
Regardless of whether or not it's your wife's car, CMOS cameras really don't provide the best image - think webcam. CCD are better, for sure. No sense in going to the trouble of installing a camera that doesn't have a wide enough field of view or sufficient image quality to be used for its intended purpose...plus, the body damage caused by backing into something because of a crappy image will be far greater than the cost of a decent camera.
Old 04-03-2008, 06:42 AM   #6
treetop777's Avatar
Yep, will do. CCD it will be. Thanks again.
Old 04-03-2008, 07:44 PM   #7
FusionFanatic's Avatar
although a regulated 12v source would be best, it will probably work fine if you wire it directly to the car's 12v supply. most backup cameras are designed to be powered directly off the reverse light wires.
I have my backup camera wired to my amp/carputer power line (unregulated 12v). I have been using it like that for about a year with no problems...
good luck
FusionFanatic is offline   Reply With Quote
My experiences with Sideways AutoSalon of Austin Texas drakino Off Topic 5 03-02-2008 05:23 PM
Rear View Mirror LCD w/rear view Camera lex4style Power Supplies 6 01-27-2007 04:38 PM
Problem with rear speakers in car beaver700 Newbie 1 05-28-2006 09:44 PM
Answer to all your car's needs : never loose your car again! Romeo Input Devices 19 10-26-2005 11:53 PM
