04-04-2008, 10:31 AM
#1
Vehicle: 2007 Corolla S
12v Fans directly to battery?
I have two case fans that I believe are wired directly to the battery (I did not install these myself).
Just wanted to check to make sure that this was fine, before they end up melting one day down the road.
04-04-2008, 10:54 AM
#2
Neither darque nor pervert
Vehicle: 2003 Toyota Tacoma X-Cab
I think they should be fine.
When the car is running, the fans would spin faster, as they would be receiving ~14v (depending on your alternator output) which might decrease the life of the fans somewhat. I don't think it would be a big deal, though.
My Worklog
04-04-2008, 11:04 AM
#3
As always, thanks Darque, appreciate the confirmation/opinion.
04-04-2008, 12:37 PM
#4
Vehicle: 2002 Thunderbird V8
Typical fans would not be sensitive to the surges and dips in voltage in a car's electrical system. As DP said, the fan speed would tend to vary somewhat but it wouldn't hurt the fan. An observer would probably not even be able to see the difference. Basically motors, relays, solenoids, lamps, and heating elements are usually tolerant of unregulated supply voltage. PC's on the other hand need regulated voltages.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/STR
~Jimmy
04-04-2008, 03:50 PM
#5
Vehicle: 98 Lexus GS300
So are they on all the time?
My carpc worklog
04-04-2008, 05:05 PM
#6
Nope - Guessing they are switched with ignition start (ACC line?) They are also in the same box as the amp/carpc, which also has the distributer block, so maybe something off that as well. But not on all the time.
04-04-2008, 06:57 PM
#7
Raw Wave
Vehicle: '02 suburban with quad captain seating
Agreed. I would not hesitate to set up like this for case fans.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
04-04-2008, 07:03 PM
#8
Nice - Appreciate the confirmations, I feel better about them now.
Once I get my car back, I'll do a full write up of the work that was done, and will see what gets knocked on.
04-05-2008, 06:12 AM
#9
Vehicle: 03 Dodge Durango SLT
Glad you posted this question, I have 4 big center console fans, and did not want to power them on the PSU, so I connected them to my switched 12v line.....
PLANNING [ 50%]
CAR PC ITEMS [ 75%]
INSTALL OF PC [ 80%]
INTERIOR MODS [ 35%]
BUDGET [ 380%]
HiJackZX1 Work Log
| Thread Tools |
| Display Modes |
Linear Mode
