Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-29-2008, 11:26 AM   #1
EPIA PD 5v Serial Voltage
I'm currently using an EPIA PD mini-ITX system for my car computer setup (it's what I had lying around for some reason). I want to hook this system up to the USART on a PIC to run the converter from my car's IEBus to the PC.
The manual for the EPIA board indicates that it supports 12v and 5v signalling levels on the serial ports (com 3 and com 4). I've got the jumpers set correctly and a serial port plugged into the com 3 pins on the motherboard, however when I check the voltages the port is still showing -12V compared to ground.
Does anyone know what these jumpers actually do? The idea I thought was that I'd be able to hook TTL level RS-232 from a PIC's USART straight to the mobo, is this not the case and I still need to use a MAX232 to convert?
electricitylike is offline   Reply With Quote
Old 04-29-2008, 03:04 PM   #2
well, i would think that the choice of 5 or 12V is just whether you wan't +-5v or +-12v rs232, 5v won't be ttl levels, but regular rs232 just at +-5volts, many laptops use this as well for some reason. You will probably still need a max232
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
_dopehead_ is offline   Reply With Quote
Old 04-29-2008, 07:53 PM   #3
Possible - either way it doesn't look like I'm getting any sort of change in behavior by flipping the jumpers I was just hoping someone might have an explanation as to why.
-12V and -5V rails explained: andrewb Power Supplies 7 03-19-2006 10:52 AM
Need help understanding efficiency and voltage regulation sansoo24 Power Supplies 3 04-22-2005 02:45 AM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 09:31 PM
Convert 1.5v, 3v, or 5v to serial signal god_of_cpu General Hardware Discussion 6 03-11-2004 01:14 PM
VIA EPIA and the UIR spud General Hardware Discussion 0 11-04-2002 02:34 AM
