The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 05-01-2008, 10:54 AM   #1
PontiacGA's CarPC Specs
PontiacGA's Avatar
Vehicle: 2003 Pontiac Vibe GT/93 Pontiac Grand Am
My Photos: (0)
AMP help.
Just hooked up the CarPC last weekend. So far, it's pulling my hair out. Everything works ok, just a few issues.
When I first turn the ign. to ACC, it fires up the the computer and the amp, then I can hear a slight buzzing and the sound of the HD spinning until windows starts, then it stops. When I stat the car, I hear the whining of the alt. or whatever, but it stops when windows starts.
I have the AMP remote hooked into the ACC wire. This is a factory amp. Would adding a relay to my DSATX JP1 'F' pin then to the amp help this? Why does the noise go away when windows starts? Maybe a sound card problem?
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Sponsored Links
Old 05-03-2008, 10:21 AM   #2
numbers's Avatar
My Photos: (0)
That would depend on how long the psu will wait before turning on the amp. Probably not more than a few seconds, so I doubt it will get you the result you're looking for. It wouldn't hurt, though.
Most likely the audio outputs are floating until the audio chip gets initialized by its drivers. In other words, the sound card isn't influencing the audio signal at all so it's free to pick up stray interference and send it to the speakers until windows takes over.
numbers is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Is this HD failure? matt11601 General Hardware Discussion 8 02-06-2007 04:16 PM
Use relay to tun on amp? Stealth97 Car Audio 7 06-25-2005 10:32 PM
Need Desktop HD to laptop Mobo Connector Joe_Collectible General Hardware Discussion 8 09-26-2004 08:38 PM
Recommendations for amp wiring kits... hd54321 Car Audio 5 08-17-2004 06:02 PM
Having problems running audio from my Shuttle to my amp 0din General Hardware Discussion 3 06-19-2003 01:41 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
