Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-13-2002, 12:12 AM   #16
m3rdpwr
Quote:
Originally posted by Mr. Pute
Can you guys with the EPIA-Ms do myself and all the other prospective EPIA-M buyers a favor and test your composite out? I saw on mini-itx.com that another website did a review of the production board and concluded that the video source reverts back to the monitor out when connected to only a composite source. This is a potential problem for me since my LCD in my car is composite. Any input would be greatly appreciated. Thanks.
Here's my bad monitor experience.
The VGA, S-Video, and composite work on post.
They all start showing the windows splash screen...
Only the VGA and S-video continue to work in Windows XP.
The composite doesn't work. I've tried several resolutions and color depths, but no luck. Any idea's?
Also, if someone knows how to shut off the POST beep through the integrated sounds card, that would be great. It was do-able with the original EPIA with the new BIOS, but not here from what I keep trying to find.
B U G G E D !!!
South Bridge CL with Vantec Copper Cooler setup. Recommended. Thanks for that one Defiler...
Thanks all in advance for the reply's... (If any.)
-Mario
m3rdpwr is offline   Reply With Quote
Old 12-13-2002, 12:23 AM   #17
Registered User
Mr. Pute's Avatar
Mr. Pute
That's EXACTLY what I saw on mini-itx.com. This sucks. I hope they fix that friggin problem soon or else I'm going to have to rework my planned setup.
Mr. Pute is offline   Reply With Quote
Old 12-13-2002, 01:50 AM   #18
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
Mine does the same thing...
I contacted VIAVPSD.com about it through the tech support online. If you guys do the same they might see this as a more serious problem and handle it quicker. I also mentioned the beep during POST.
Defiler is offline   Reply With Quote
Old 12-13-2002, 12:24 PM   #19
Mikesz's Avatar
Mikesz
After the post screen is when the video drivers take over. Sounds like a driver problem to me. Look through the advanced settings in your video properties. There should be options to turn on and off all of your video outputs. Try uninstalling the video drivers. You might be able to limp your system along in 640x480 mode with the composite video out working in the car until the fix comes out. maybe...
mike
91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
Mikesz is offline   Reply With Quote
Old 12-13-2002, 01:11 PM   #20
m3rdpwr
Had already tried that with no go.
What I might do is get a s-video to composite adapter.
They only cost a couple bucks and should work. (I hope)
Thanks though...
-Mario
Old 12-13-2002, 01:23 PM   #21
Raw Wave
Defiler's Avatar
Here's what I got from VIAVPSD:
Thank you for your support to the VIA Mainboard (VPSD) Website
We have received your inquiry email and the reply as follow-
Dear Michael, Please check the RCA/SPDIF jumper and set it to RCA to enable composite video out. Thank you. Regards, tech support
VIA Technologies,Inc.
940 Mission Court, Fremont, CA 94539,
Sales Support: 510-687-5771
Tech Support: 510-687-5772
Email: VPSD_Sales@viatech.com
Email: VPSD_Marketing@viatech.com
Email: VPSD_TechSupport@viatech.com
http://www.viavpsd.com/vpsdcontacts/
I haven't tried yet but I think it's already set to this. I will check it out tonight.
Old 12-13-2002, 01:27 PM   #22
m3rdpwr
It is set by default.
I tried it both ways anyway.
If you look at the manual, there is a misprint.
It says 1-2 for Composite and 3-4 for video out.
Or something like that.
But, no go still...
The other thing you must remember, is that it works.
Just not when Windows is fully loaded...
There response to me even though I told them I had tried it in the first email:
Dear Mario,
You have to enable the TV out through composite connection in Windows with
CRT first. The video driver will enable you to select the screen out option.
As for the POST beep, the only option so far is to disconnect the audio jack
when you power on.
Best Regards,
VPSD Technical Support
-Mario
Old 12-13-2002, 08:10 PM   #23
m3rdpwr
Check this out:
http://www.silentpcreview.com/module...rtid=50&page=1
They talk about the same problem on page 2.
TV Hookup
A Panasonic GAOO 27", two years old, with S-VIDEO and other inputs, is the only TV available. It is a high resolution TV with excellent picture quality. It was connected to the PC via a 6 foot long S-VIDEO cable. For reasons that could not be determined, the TV resisted all attempts to display the PC output beyond the bootup script. As soon as the Windows screen appeared, the TV screen simply went blank. The same problem was encountered with the other systems, one with a Matrox G550, the other a Matrox G400 Max. Nothing worked, so for now, the TV looks like the culprit. This issue will continue to be explored (with help from VIA) and a followup posted when more information is available.
-Mario
Old 12-13-2002, 08:36 PM   #24
m3rdpwr
Found the problem!!!
Go into video properties and advanced.
Click the S3 Display tab.
Place a check-mark on TV.
Don't stop there!
Than click on the picture of the TV.
You will see more options appear!!!!!!
I went into advanced and hit + on size.
I found I had to reset the refresh rate on the monitor.
Even on my new 36" HDTV TV it's tough to read.
s-video is tons better.
Quality isn't good, but hey whatta' ya' want.
Good luck to you guys!!!
-Mario
Old 12-16-2002, 02:45 PM   #25
Registered User
Mr. Pute's Avatar
Mr. Pute
Mario,
The problem is, when the computer is powered up in say, a car with a composite LCD, the EPIA-M won't directly default to the composite output until you manually. Are you saying your little trick corrects this problem? Can anybody else confirm this?
Old 12-16-2002, 03:26 PM   #26
m3rdpwr
If you are having a "bios post" composite problem, most people said putting a 75 ohm resister across the composite would trick the motherboard into thinking the composite monitor was on and connected.
The problems a few of us were having with the EPIA-M was no video after windows was loading...
-Mario
