The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 05-08-2008, 09:04 PM   #1
My Photos: (0)
Intel D201GLY2A - USB Ports won't work at all! Help!
Hey everyone,
I recently got the D201GLY2A board installed and I finally got Windows installed on it (Via a PS/2 keyboard). Now I've finally realized that my USB ports don't work. Whether hooked up directly to the motherboard or through a hub none work.
I'm positive all Bios settings are enabled for USB ports working. Does anyone have any suggestions why this would happen? I don't believe its a power issue and PS2 does work fine. Is there a particular setting I'm missing? Anything? This is driving me nuts!
PDiddy is offline   Reply With Quote
Sponsored Links
Old 05-09-2008, 10:32 AM   #2
BlackStealth's CarPC Specs
Vehicle: 93 Twin Turbo Dodge Stealth
My Photos: (12)
Did you forget to install the motherboard drivers?
BlackStealth is online now   Reply With Quote
Old 05-09-2008, 11:06 AM   #3
My Photos: (0)
hmm well I bought it from Chris at Mobile Solutions so I assumed they were installed and ready to go. Do you install those drivers through Windows?
From this list I couldn't find anything pertaining to the chipset installation:
http://downloadcenter.intel.com/Filt...ting%20Systems
Old 05-09-2008, 12:49 PM   #4
My Photos: (12)
When you open up device manager, can you see the USB host controller?
Old 05-10-2008, 08:45 PM   #5
My Photos: (0)
Well it turns out that it was because I had USB 2.0 parts enabled in my BIOS. I assumed that it should be enabled but as soon as I disabled it, Windows recognized all my USB devices correctly.
Old 05-10-2008, 10:44 PM   #6
nst6563's CarPC Specs
Vehicle: 2004 Nissan Maxima
My Photos: (0)
I have that same board and have all the USB 2.0 options enabled and don't have any problems. Have you tried a bios update? I noticed my board shipped with an older bios and just updated it for good measure. Could possibly be your problem. But I don't think it has anything to do with drivers since it seems you were having problems before installing the OS, also, I don't have any special drivers installed for the chipset and have no issues either. USB support is native in bios functions and shouldn't require any drivers to operate, and since USB 2.0 is backward compatible with USB 1 it would lead me to believe there is something deeper going on there. I'd start with resetting the bios to defaults and if that doesn't work then I'd flash to the most recent update.
If that doesn't work I'd call Intel and see what they have to say about it. No excuse to have to live with a board where you have to disable USB2 functionality in order to function.
nst6563 is offline   Reply With Quote
Old 05-12-2008, 07:02 AM   #7
My Photos: (0)
I do believe I have the latest bios. On the USB configuration do you have USB Legacy enabled or disabled? Right now I have them enabled and have the 'USB Ports' set to enabled but 2.0 disabled. I have heard that having USB Legacy enabled slows Windows boot times down so I may disable that and see what happens and go from there. As of now I'm just relieved its working all together.
Old 05-12-2008, 10:16 PM   #8
My Photos: (0)
I actually had ALL USB options in the BIOS enabled. Maybe it's one or more of your USB devices that just doesn't like it?
Old 05-13-2008, 02:14 AM   #9
My Photos: (0)
try to reinstall again, usually some file are missing. after that you had to restart it. hope this can help
Nico John
zone-car.com
nicokpe is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
how to effectively use usb ports? maloosheck General Hardware Discussion 10 06-06-2007 11:35 AM
Installing a USB Hub up-front? Read this... hd54321 General Hardware Discussion 13 02-09-2007 11:49 AM
fried USB ports alti General Hardware Discussion 3 07-09-2005 11:27 PM
DVD Rom IDE to USB, 25ft. would it work? mattress General Hardware Discussion 9 02-04-2005 03:03 PM
Via Epia Questions - need multiple serials, ps/2 ports, USB nxt125 General Hardware Discussion 2 08-07-2002 08:08 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
