Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 09-04-2008, 11:36 PM   #91
NiSlo's Avatar
NiSlo is an unknown quantity at this point
Quote: Originally Posted by Woofnstuff View Post
the dual core is out
Yeppers! I had bought the d945GCLF a couple of weeks ago but hadn't put it in yet, so when I saw that the dual core had come out I sold it - now I just need to find somewhere that stocks it already !
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 09-08-2008, 05:16 PM   #92
webwiznz is an unknown quantity at this point
Ive found the intel essential series boards to have very picky ide controllers.
Some of my CF-IDE adapters work some dont. Some 2.5"-3." pata adapters work some dont. So far havent found a pattern to it. It would be good to get to the bottom of this.
webwiznz is offline   Reply With Quote
Old 09-08-2008, 08:03 PM   #93
sushisan is an unknown quantity at this point
Hi:
I have readed a lot of reviews about D945GCLF.
I have some questions that I think are no clear
1) The power consuption is very variable in the reviews. What is the REAL consumtion of the mother (without any SATA ,IDE, USB or PCI attached???)
2) There are a power connector for 12V P4 (the 4 pins near the CPU). What happen if are not used?
sushisan is offline   Reply With Quote
Old 09-08-2008, 08:18 PM   #94
I measured actual 12 volt dc draw (of the dual core version) here:
http://www.mp3car.com/vbulletin/1250425-post44.html
Because atom draws so little the actual power draw on the 12v 2x2 conecter is very little. Nonetheless its still required, a computer with no power to the CPU is no computer.
See
http://download.intel.com/support/mo...35968001us.pdf
0.8 amps total on 12 volt. Most power is used on 5 volt rail, upwards of 8 amps.
Old 09-08-2008, 10:24 PM   #95
Yes, I have readed the intel pdf, and speak about 7A BUT with one hard disk drive, one optical drive, and all board peripherals enabled
The minimum recommended power supply is 75 W.
The following table said that use 7.75A@5.5V and 0.51A@3.3V this is arount 45W
This numbers are consistent with your comment ! TXS
PD: the 8A is a peak or is consistent? (an LM 338 can regulate 5A with a peak of 7A)
Old 09-08-2008, 10:46 PM   #96
Ive just had a protracted email dialog with my supplier and they are certifying the procase/morex cs-3688 case as atom friendly (D945gclf2). The DC board in this chasis is a morex sh-6080 with specs:
3.3V 5A
5V 5A
12V 2.5A
more suited to EPIA stuff.
I think so long as you dont go plugging heaps of USB stuff in it should squeak in. But personally ill be upgrading the board to morexs 150 version which is rates at 8 amps on the 5 volt rail.
The good thing about the dual core atom board is the north bridge HSF has been reduced in height from 45mm to 30mm and its this factor that makes this case work at all.
Old 09-09-2008, 06:07 AM   #97
I have 2 D945GCLF , not D945GCLF2. I'm not sure about the difference in power consuption
Old 09-09-2008, 12:13 PM   #98
shiltz's Avatar
shiltz is on a distinguished road
Does anyone know if this board will work with an M1-ATX PSU? only concerned because of the low 12V rail on the M1, on the computer I have a DVD drive which really I never even use and may just ditch it and use a USB when/if I need it, i'd be getting an SSD drive, I do currently have a geforce MX4000 video card there but that's stricktly so I can get 800x480, so if with the updated bios this can do that res then i'll be ditching that, and there's my GPS reciver, touchscreen, and an occation thumb drive plugged into the USB ports, don't have any case fans atm with my MII10lk board, and it's deen fine, not sure if ones needed with this M/B but really I can just hook that up to the car's power instead to not add more 12V load to the PSU.
VIA MII10000, 512mb, EVGA MX4000, Xenarc 700TSV, M1-ATX PSU
G.Skill 64GB SSD, Panasonic slimline slotload CDRW/DVD ROM
shiltz is offline   Reply With Quote
Old 09-09-2008, 01:34 PM   #99
rickd is an unknown quantity at this point
If you don't power the four-pin connector, the motherboard will not operate at all. I have, uh, tested this.
Regarding power consumption, I have measured this in a careful way.
My computer uses the D945GCLF, with a 1-gig DDR2 memory module, a full-time fan for the chipset (powered from the 12V rail), a case fan plugged into the system fan header on the mobo, a 2.5" 120G SATA HDD, an IDE-interface compact flash adapter, a 10.4" touchscreen display, a "slim" CD/DVD combo drive, keyboard, mouse, a Garmin USB GPS puck, and a Belkin USB wireless Ethernet interface. All devices supported by the chipset are enabled. The computer draws 34 watts continuously at 13.6 volts from a regulated power supply. When spinning up a DVD or CD at full speed, the consumption goes to 40 watts continuous, maybe occasionally peaking to 41 watts. I am not guessing here, these are careful measurements made with the right equipment.
The power supply is an M2-ATX-HV, which at this input voltage is about 98% efficient.
I'm running the monitor from the 12-volt rail--it's plugged into an HDD power connector.
I have not run it without the drive, but without the monitor, the USB wireless interface, and without a CD in the combo drive, the consumption is about 20 watts. The fans together consume no more than a watt or two.
Those who are using up 50-75 watts with this motherboard must be running some big honking 3.5" hard disks, or really hammering the processor and chipset. My tests were run with XP Professional (with nothing done to reduce consumption), Garmin Mobile PC running, and playing Solitaire (that touchscreen makes Solitaire a lot more fun, heh, heh). I get the same power consumption no matter what OS I run, and I can boot this box up in either XP, Ubuntu, or MS-DOS.
RickD
rickd is offline   Reply With Quote
Old 09-09-2008, 08:30 PM   #100
Rickd:
TXS!!! with this values I can finish my PSU (in Argentina a DC-DC PSU is impossible to find! I can construct one of these for 50W for less of U$S50)
Old 09-14-2008, 01:02 PM   #101
RyanB95's Avatar
RyanB95 is an unknown quantity at this point
Is anyone else having this problem all of a sudden?:
The AA number has not been programmed...
Press enter key to continue
On startup? Even from hibernate I get this message every time. Not only do I not want to press enter EVERY time the computer boots up, but I also don't even want to have to keep a PS/2 keyboard in my car at all times. This is very frustrating.
I have read that a BIOS update fixes the problem, but I can't even update the BIOS. The installer says "The program is unable to continue. The BIOS you are trying to update to is invalid for your system."
I also tried using the DOS based update from a USB Flash drive and that doesn't work either. I can't get it to boot from USB (everything is enabled in BIOS to boot from USB).
What's the deal?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
Logitech DiNovo Mini
LSX VOID 3.3
RyanB95 is offline   Reply With Quote
Old 09-15-2008, 02:09 PM   #102
RyanB95's Avatar
Turns out it doesn't like having a PS/2 keyboard plugged in on startup. I unplugged the keyboard and now it boots up without a hitch. It still says the AA number has not been programmed to the system but now it doesn't require me to press enter to boot it up. Wonder what the problem is?
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 09-15-2008, 03:21 PM   #103
BlackStealth is on a distinguished road
My carpc has a ps/2 keyboard plugged in all the time without any problems. Try flashing the bios to the latest version if you can.
BlackStealth is offline   Reply With Quote
Old 09-16-2008, 07:18 PM   #104
RyanB95's Avatar
BIOS won't update... the post above the one you read explains.
1995 AWD Tsi Talon
Intel D945GCLF
M2-ATX
2GB Corsair
30GB OCZ SSD
BU-353
Lilliput EBY-701
LSX VOID 3.3
Old 05-16-2009, 10:56 AM   #105
sensibull is an unknown quantity at this point
Not much activity on this thread, but I figured I'd post here instead of starting a new one...
I'm having the exact same hibernation/resume problem as described below (also using an m2-atx). Just updated to the latest BIOS and still no fix. Has anybody figured out why this is happening?
Quote: Originally Posted by sivart321 View Post
I have this exact same problem. It has worked on and off. Sometimesd if I take it directly from the house, set the res to 640 x 480, itll boot up and display everything just fine. Other times, itll start to boot up (ill see "resuming from hibernate") and then itll lose the display connection. I never had a problem with any of the other boards ive used in the car. Same PSU, etc.
Portecho: Entertainment Technology News, Reviews and How-to's
sensibull is offline   Reply With Quote
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 03:56 PM
FS: Mobile Intel Pentium 4 Processor - M 2.20Ghz CPU $100 shipped OBO DLe Classified Archive 5 05-11-2006 07:48 PM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 02:16 PM
Micro ATX / Mini ITX (AMD, Intel, VIA) wanjer Newbie 2 09-11-2004 08:31 AM
Whats better: Matrox Millenium g450 or Intel 845G integrated AGP4X video controller? psyclobe General Hardware Discussion 2 10-24-2003 10:28 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
