I'm adding 6 more car PCs to my install, but didn't want anything over powered so I found the Intel D945GCLF. I had some questions though since this seems to be a very popular board, or it was very popular. I see alot of people have moved onto the dual core version, something I don't need.
Basically my main PC will be for heavy stuff, like Sat TV, 3D Video games and what not. I wanted each passenger to have the ability to switch to a personal PC and do things like go on the internet, watch videos, chat, music, thats about it. Will this board be able to handle that?
How is the heat on this MoBo? I intend to build these into each door, in-cased in HP T5510 Cases which fit mini-itx boards perfectly. If heat is an issue I can always make vents for the processor fan.
What is the lowest PSU wattage I can use. I need something really small, doesn't produce alot of heat, etc. These units will not use DVD Rom, they will connect to the main PC one via network share. Only devices that will be used are 2 USB ports, one for the arm rest for gadgets they want to use, and the other port will be used for a KVM which houses the Keyboard and Touchscreen. The on board sound, ethernet port and on board graphics will be used also, but other then that, nothing else at all.
HiJack ZX1 CFSC
CAR PC ITEMS [ 35%]
INSTALL OF MULTI PC SYSTEM [ 35%]
BUG WORKOUT [ 0%]
INTERIOR MODS [ 45%]
HiJackZX1 Work Log
HiJackZX1 Website!
Please build up my REP.
