Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 12-17-2002, 03:49 PM   #1
CarComp's Avatar
CarComp is on a distinguished road
Something everyone should know about sound cards.
I learned recently, from installing a few more computer systems into people's cars, that sound cards DO NOT truly put out the same kind of power that a normal head unit does. True, it is close, and does work, but I have found that you can reduce a lot of "electrical noise" that the computer / car generates if you follow these few guidlines.
1. Ground your soundcard to your car's ground. Also ground your cdrom casing to the car's ground.
2. Use a ground loop isolator between your sound card and your amplifiers (readily obtainable from Radio Shack). Keep it away from any power / speaker wires, because it WILL pick up noise. The isolator removes any power supply induced hiss / noise.
3. Invest in a good Pre Amp. Audio Control makes a good one called The OVERDRIVE that can match your output from your sound card.
4. In conjunction with the Pre Amp, set your amplifier gains to their minimal settings, then set your computer volume at 3/4 max. Begin turning up your amplifier gains until you hear clipping / distortion.
5. In Windows: Mute all un-needed volume controls. Usually the mic, the modem, and any others that you do not use.
That should get rid of the noise.
Get MediaEngine !!!
Media Engine Download
CarComp is offline   Reply With Quote
Old 12-17-2002, 04:09 PM   #2
YoMaMaZPHaT
Guest
Posts: n/a
instead of going with a pre-amp, could you just run the soundcards output into the aux input on an aftermarket CD player and get the same effect? or does this not prevent the problem of not putting out a much power as just a HU by itself?
Old 12-17-2002, 05:51 PM   #3
magnetik
Carcomp, I agree with all your statements EXCEPT that of the ground loop isolator.... I find them to distort/ruin sound output and is really more of a 'cure' than a 'prevention'
follwing your other steps, if you still have noise problems I would be looking at the quality of the sound card itself....
Project - GAME OVER :(
magnetik is offline   Reply With Quote
Old 12-17-2002, 11:08 PM   #4
SuperMatty
I disagree with the set software volume to 3/4. That is an arbitrary value that has no basis or reason. Mine is turned to 100% and I have no noise except at my highest 1/10 of my head unit volume.
SuperMatty is offline   Reply With Quote
Old 12-18-2002, 06:56 AM   #5
CarComp's Avatar
Those values were assuming that you have no head unit installed. If I use full volume on my puter, I get a nasty case of clipping. Not distortion, but I lose the quit a bit of my mids.
Get MediaEngine !!!
Old 12-18-2002, 10:11 AM   #6
jol
jol's Avatar
jol is on a distinguished road
In Sweden, we user triple-shielded cables, guess there's plenty for everyone
My cars
jol is offline   Reply With Quote
Old 12-18-2002, 10:19 AM   #7
t0ffluss
Quote:
Hear hear hehe
(In Norway too)
Richard
"If A equals success, then the formula is: A=X+Y+Z. X is work. Y is play. Z is keep your mouth shut."
Albert Einstein
t0ffluss is offline   Reply With Quote
Old 12-19-2002, 10:02 AM   #8
Mikesz's Avatar
Mikesz
I have a sound blaster live and it has loads of voltage on the outputs. More than most stock headunits. I have the gains on my amps set to about 1/4 to 1/2 if i remember correctly.
mike
91 cadillac sedan deville, winXP, FV25 with Celeron 800, Redant 7" widescreen in dash, Opus DC-DC, Irman, Digital Cable remote(lots of buttons), 120 gig 7200rpm 8meg cache WD hard drive, VI power mobile HD rack, mediaengine
Mikesz is offline   Reply With Quote
Old 12-19-2002, 10:00 PM   #9
Registered User
Cliff
I agree about the Ground Loop Isolator...it takes away from the overall sound (does a good job at taking hiss away) and takes most of all bass tones. I took mine out and the difference was HUGE, so I started putting up with the hiss again. Then again, Im running off of an inverter, so as soon as OPUS's new PS comes out that should solve alot of the hiss problem...
Also, I also found that turning my windows volume up to 100% really starts to distort the higher frequencies...I turn it down to about 85% and it sounds best. But this is with the integrated sound in a Via Epia 800 im using...so that could be the problem too. Getting an audigy soon, that and a good ol DC-DC should do it! =)
Grand AMplifier Project 1.0:
http://drive.to/cliffsgrandamgt/
http://www.astallaslions.com/carmp3/
-Eden 800 mini-itx motherboard
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
-PB Remote /w Girder
-Media Engine & Windows XP
-Playstation II also added
-Steering Wheel Buttons modified for Control.
Cliff is offline   Reply With Quote
Old 12-19-2002, 10:45 PM   #10
magnetik
good to see someone else had the same experences with Ground Loop Isolators....
Cliff, once u get your Audigy you will notice the difference.... im running an inverter with my Audigy and it sound fantastic... going DC-DC in the new year with a EPIA 800 (keeping the Audigy of course!) so all should be supa sweet...
Old 12-19-2002, 11:29 PM   #11
YoMaMaZPHaT
Guest
Posts: n/a
what are good brand power invertors? I will need to be getting one soon, the power supply ill have on the computer is 300watts, so would it be good to get a power intertor rated at 400watts?
Old 12-19-2002, 11:39 PM   #12
magnetik
common mis-conception......
a 300W PSU does NOT mean it will draw 300W, but can handle upto 300W of load...
for example I have a 300W PSU and only a 140W inverter running in my setup of a Duron 800Mhz/40GB HDD/5.6Inch TFT.... thus the mp3car setup obviously draws less than 140W and ALOT less than 300W
good brand of inverters?? wouldnt know..... I got mine from www.jaycar.com.au in Australia, but thats prob a little use to you!
Old 12-19-2002, 11:49 PM   #13
Registered User
Cliff
I have a Jensen 300w which my alternator doesn't like at all, I think it's giving it a beating...
Jensen are usually what people go with. They are good inverters.
Mag: Cool. Im looking forward to the audigy. I just have to find a pci riser slot for the mobo first though, you will need one too when you get your epia..
-5.6 NTSC TFT-LCD
-80 gig hard drive
-128 MB RAM
-MPBS1 DC-DC PSU
Old 12-20-2002, 05:59 PM   #14
stinkynathan
Re: Something everyone should know about sound cards.
Quote:
a very, VERY good gain-setting tutorial is here. Also has some other install links and info. they guy is definately a different character, but he knows his audio and electronics...
later,
nathan
stinkynathan is offline   Reply With Quote
Old 12-20-2002, 07:40 PM   #15
bstanton
my carputer draws 130watts continious (no floppy / dvdrom) off my 180watt power supply unit, and my 140watt Radio Shack inverter (300watt surge) works fanastic.
bstanton is offline   Reply With Quote
