I thought it looked familiar...
http://www.cappuccinopc.com/mochae5042b.asp Definitely not junk, and leaps and bounds better than some of the VIA or EPIA stuff pound for pound.
It's the big brother of the same
carPC I was using, which was GREAT BTW. Basically bulletproof. Mine was/is a 1.3 Celeron processor w/256mb RAM. If I had to say anything "bad" about mine, it was the fact the USB was only 1.1. Don't get me wrong, I had a few hubs hooked up to it with GPS, 2 Mice, 2 Keyboards, TS, External CD/DVD drive, Wireless USB adapter and a partridge in a pear tree, and never had a problem. But I felt USB 2.0 would be better.
FYI, I picked up 2 of these at the auction today, my offer was $59.00 ea, and they went for it. So, for about $150.00 shipped, I now have 2 more machines that are a little faster, little more memory, and USB 2.0.
The only thing that conacerns me is why they were having trouble loading Windows on it. Maybe a bad Bios battery or something. Guess I'll just wait and see.
I'll bet I can even swap out the case, since I custom painted mine to match my car. I may even try just dropping in my current HD and booting it up to see what happens.
Chipset
SiS 651
Processor
Support for an Intel Pentium 4 processor in mPGA478 socket with a 400/533 MHz system bus.
Support for an Intel Celeron processor in mPGA478 socket with a 400/533 MHz system bus.
Runs on the latest Intel Socket 478 Pentium 4 CPU that includes 512KB Advanced Transfer Cache. The P4 CPU is available clock speeds starting at 1.6GHz.
Intel processor ensures your PC is fully compatible with an entire library of PC software based on server al operating systems especially Windows 98, Windows ME, Windows NT, Windows 2000, Windows XP, and Linux
Main Memory
Provides one 200pins DDR SODIMM (Small Outline Dual Inline Memory Module) memory slot for main system memory configuration up to maximum 1GB.
Uses DDR266/333 SODIMM module at 128MB, 256MB, 512MB module and 1GB Module.
Audio System
Built-in 16-bit stereo Sound Blaster compatible, full duplex 3D Stereo Sound
Built-in Speaker
One 3.5mm microphone input jack
One 3.5mm earphone jack
Flash BIOS
Flash EPROM BIOS allows you to easily upgrade the system BIOS using the Flash utility program
Storage
Built-in high-capacity 2.5-inch (9.5mm and 12.5mm high) Hard Disk Drive and supports Ultra-DMA 66/100/133
Built-in CD-ROM or DVD-ROM or CD-RW or Combo Drive
USB port External Floppy Disk Drive
Video
Built-in full-motion video accelerator
Hardware motion compensation for Software MPEG-2 (DVD playback)
Integrated 64MB shared Memory
Supports up to 1600 by 1200 pixel resolution at 24-bit color
15-pin mini D-sub VGA connector for external monitor
AGP 2.0 compliant (4X)
I/O Ports
2 x 4 pins mini type Firewire 1394 Ports
2 x USB 2.0 Ports
1 x 9-pin Serial Port (RS-232)
1 x 25-pin Parallel Port (EPP/ECP)
1 x 6-pin PS/2 Mouse Port
1 x 6-pin PS/2 Keyboard Port
Communications
Built-in Realtek 8139 10/100MB Fast Ethernet (RJ45)
Built-in PCtel HSP56MR 56K V.90 Modem (RJ11)
Electrical Requirements
Auto sensing AC input 110-240V at 2.5A, DC output 20V at 6.0A
Maximum Power 120 Watts
Data and Media Storage
One 2.5" 12.5mm high hard drive (ATA 133/100/66)
One ATAPI-IDE interface for high speed slim type CD-ROM, DVD-ROM, CD-RW, or DVD-Combo
Weight and Size
Weight: approximately 1050g (2.31 lbs)
Dimension: 157mm x 146mm x 56mm (6.18" x 5.75" x 2.2")
