The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-23-2008, 05:04 PM   #1
Ricksastar's Avatar
Vehicle: 2006 Ford Explorer
My Photos: (0)
Good for bench testing??
Hey everyone.. I am building my comp now in the work shop will this be fine for testing?
http://www.autozone.com/R,NONAPP3042...ductDetail.htm
Ricksastar is offline   Reply With Quote
Sponsored Links
Old 06-23-2008, 06:23 PM   #2
Stealth915's CarPC Specs
Stealth915's Avatar
Vehicle: 2004 Mazda3s
My Photos: (3)
that looks like it should work for bench testing.
I (like many other people here) have an old computer power supply laying around, so I just short the two pins on the ATX connector and use the 12V line on a molex connector to simulate getting 12V from a car battery.
http://www.mp3car.com/vbulletin/faq-...workbench.html
Stealth915 is offline   Reply With Quote
Old 06-23-2008, 06:28 PM   #3
Caelric's CarPC Specs
Caelric's Avatar
Vehicle: 2005/Infiniti G35 6MT Coupe
My Photos: (0)
Yep, thats the cheapest way to bench test, and works great. It's how I do mine
2005 Infiniti G35 6MT Coupe Black/Black
Core Duo CarPC
CarDomain page
Caelric is offline   Reply With Quote
Old 06-23-2008, 10:32 PM   #4
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
A battery CHARGER like the one linked usually has a pulsing output; that works better for charging batteries. You want a constant output (more or less) instead of pulsing. You can use the charger but it is best if it is also connected to a battery for it to charge and then your battery will filter and smooth the output somewhat. Then you can run whatever off the battery while it is being charged, much like when your alternator is charging it. The simpler way like others have said on here is to use an old ATX supply or some other 12V regulated output supply.
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Lilliput 629GL-70NP any good? bmw328i LCD/Display 4 05-30-2005 09:47 PM
Anyone from Chicago know where to get a good install?? gitrplyr09 Newbie 8 02-25-2005 12:32 PM
Question on good MB for suspend modes. tsm_man Newbie 0 01-12-2005 05:51 AM
Are these a good LCD? mainfraim LCD/Display 4 05-18-2002 05:37 PM
Testing a power supply to see if good or dead? Squeezer Power Supplies 3 03-17-2002 12:19 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
