The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 06-26-2008, 11:03 AM   #1
Ge0
Vehicle: 2004 Durango Limited
My Photos: (0)
In search of ultra slim firewire card option
Sorry for the crappy photos. I'm at work and don't have access to better images for the time being.
I am constructing a CarPC for the sole purpose of audio processing.
The sound card I chose is external and communicates over the firewire buss.
The problem, my motherboard does not have a firewire port. I do have an empty PCI slot though. I am currently searching for an ultra low profile, single port, firewire card. Here is what I have found so far:
http://www.newegg.com/Product/ShowIm...odel+PCI1394_2
The card height off the PCI connector is acceptable. It will barely clear the top of the VoomPC case. However, obviously I can't use the card edge connector in a Mini-ITX VoomPC CarPC case. As a matter of fact, I don't have room for the card edge connectors in general even if I do remove the metal card edge tab.
From that picture one might think that the external firewire ports would just reside next to the audio ports on the motherboard once the card is plugged in. However, this will not be the case. The external power jack for the PSU resides at this location.
So, to use the card from Newegg I would need to cut off the end of the card where the external firewire ports stick out. Next, I'd have to desolder the internal connector and put it on a extension header. Seems tedious but it is doable. I'd prefer a more elegant solution.
Does a PCI to Firewire card exist that DOES NOT have external connectors? All I need is one internal port.
I could re-locate the external power connector and keep the Newegg card in tact. However, I like the power connector where it is at.
Did I thoroughly confuse everyone?
Have an idea about alternate cards?
Thanks.
Ge0
Ge0 is offline   Reply With Quote
Sponsored Links
Old 06-26-2008, 01:29 PM   #2
FPeter's CarPC Specs
FPeter's Avatar
Vehicle: 2005 / Opel / Astra H Z17DTL
My Photos: (7)
i think its nearly impossible to find a card without external connectors... but you can cut off the "head" of the linked card...
just saw off the unneeded pcb part with the connectors, then check if there is a short circuit somewhere on the cutted edge - scratch it with a knife if required, than put it into the pci slot, and fix it with fishing line...
Intel D201GLY, 512MB DDR2, Maxtor 3.5" 40/7200/2M HDD, audio through digital line
bye bye noise - the DIY S/PDIF DAC
FPeter is offline   Reply With Quote
Old 06-26-2008, 02:01 PM   #3
JimmyFitz's CarPC Specs
JimmyFitz's Avatar
Vehicle: 2002 Thunderbird V8
My Photos: (0)
Post Flexible PCI riser may help
would this allow you to reposition inside the case enough to keep it internal without cutting on the PCI card?
http://www.logicsupply.com/products/pci101_flex
2002 T-Bird, Via SP13000, Travla C158, M1-ATX, 1GB RAM, 120GB 2.5" drive, SlimSlot DVD-RW, XP, RR, Winamp, Xenarc 700TSV, HTC Touch PPC/Phone, BU-353 GPS/iG3, Elmscan OBDII, Griffin PowerMate, 2 Blaupunkt amps, Polk spkrs, 5 sec startup/S3 STR
~Jimmy
JimmyFitz is offline   Reply With Quote
Old 06-26-2008, 02:12 PM   #4
Ge0
My Photos: (0)
Thank you very much for your input. I'm not sure if you were following what I said above, but, this is exactly what I was trying to explain.
I design PCB's for a living. I've cut my share of cards in the past. I should be able to do this little job without too much damage . Just a little messy.
I was wondering WTF you were talking about when "fixing it" with fishing line. But then I looked closer at your photo. Smart!
Thanks again,
Ge0
Old 06-26-2008, 02:13 PM   #5
Ge0
My Photos: (0)
Might be an option. I'll take a look into it once I get home.
Thanks for the link!!!
Ge0
Old 06-26-2008, 02:28 PM   #6
FPeter's Avatar
My Photos: (7)
Thanks again,
Ge0
sry, i missed it...
and what about the minipci slot on the mobo? you will get internal connectors with a minipci firewire card...
Old 06-26-2008, 02:45 PM   #7
Ge0
My Photos: (0)
sry, i missed it...
Definitely the best option. I did not search much, but so far the cheapest card I could find was $75. Seems a little over inflated seeing how I can get the Newegg card for $12 shipped.
Any idea where I could score one of these for around $25 to $30? I might be more inclined to go this route .
Thankx again.
Ge0
Old 06-26-2008, 03:25 PM   #8
Ge0
My Photos: (0)
sry, i missed it...
I was bored and decided to look at the pictures you have posted to the public in the name / info bar to the left of your posts. Did you mill those boards out of copper clad using a mini-CNC machine? Nice work. I used to have something similar in my lab.
Ge0
Old 06-26-2008, 04:40 PM   #9
FPeter's Avatar
My Photos: (7)
Ge0
it might be a misunderstanding, but do you mean my circuits?
Old 06-26-2008, 04:44 PM   #10
Ge0
My Photos: (0)
Yes, of course. Just asking if they were etched or milled? They look pretty good for a home-brewed etch job. That is why I was iquiring on the milling machine.
Ge0
Sponsored Links
Old 06-26-2008, 04:50 PM   #11
FPeter's Avatar
My Photos: (7)
Ge0
etched, and its simplier than you think! i will write it down in my topic that i linked in my signature...
Old 06-30-2008, 10:59 PM   #12
Ge0
My Photos: (0)
Thankx again.
Ge0
Quoting myself!!!
Well, does anyone have an idea where I can score a somewhat cheap FIREWIRE mini-PCI card?
Ge0
Sponsored Links
vB code is On
Trackbacks are Off
How do I search songs / Why my search doesn't work ? guino RR FAQ 0 07-29-2005 11:46 AM
FAQ: Why do people keep telling me to SEARCH? tj!2k4 The FAQ Emporium 1 06-28-2005 01:06 PM
Search function issues... Tim97rs Newbie 5 05-28-2005 11:05 PM
The "Official" low profile card post lakorai General Hardware Discussion 8 05-22-2005 08:49 PM
Is the search option working? Falcon62Travis General MP3Car Discussion 4 04-21-2001 11:29 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
