The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 07-16-2008, 03:16 PM   #16
Raw Wave
TruckinMP3's CarPC Specs
TruckinMP3's Avatar
Vehicle: '02 suburban with quad captain seating
My Photos: (0)
Quote: Originally Posted by ctx32 View Post
That's my main concern, durable and temp.
I came to this site because I know if anyone knows about this stuff it's you guys.
This setup is going in my Lifesize R2D2 droid and the pounding and heat will be
pretty rough sometimes.
Don't nail me to hard fellows " I'm not a robot freak" atleast that's what I keep telling myself.
I just need some help from someone with experience in this area and this will complete my $7000.00 project.
Calvin
consider using a small and low power mb with whatever drive you determine fits your need.
I like this MB: http://store.mp3car.com/Intel_D201GL..._p/mtb-054.htm
because the power use is low and the size is small 6.75 x 6.75 inches footprint.
Your space considerations may lead you to flash storage but cost may lead you to used laptop drive.
Maybe an older used laptop will fit your need.
Another consideration is power source, in a car with the engine running a 12 volt DC to DC solution works... that may work for you as well, depends on power consumption and projected run time along with your battery size.
Many of us will be happy to offer opinions on your project but you will need to make your own choices.
TruckinMP3
D201GLY2, DC-DC power, 14in LCD ;) 3.5 inch SATA
Self Proclaimed Spoon feeder!
Read the FAQ!
TruckinMP3 is offline   Reply With Quote
Sponsored Links
Old 07-16-2008, 04:57 PM   #17
My Photos: (0)
That's the board I picked.
I have been looking at the new Intel D945GCLF.
Power consumption is a big concern.
I'll have 2 batts configured in 24v. and 2 for 12v.
The only program besides Xp it will need to run will be my
Visual C# code.
Hopefully it does'nt kill the batts to quick.
Calvin
ctx32 is offline   Reply With Quote
Old 07-19-2008, 06:24 AM   #18
HiJackZX1's CarPC Specs
HiJackZX1's Avatar
Vehicle: 03 Dodge Durango SLT
My Photos: (254)
Why am I not getting emails from Mp3Car..... ARGGGHHHHHHHHHH.
Well like Truckin said, the findings cant be denied, but doesnt SSD have slower read and write rates?
ctx32...... Best thing to do is research and research alot. Dont jump into anything with out researching it first. I decided to jump into my install with no research and have wasted almost $2,000.00 on things that did not fit my build. I have since redone my build which cost me about $4,000.00 with top grade stuff, but my install is also alot more massive then most (thats why I drive a SUV), so in all ive spent about $6,000.00 dollars and you just dont know how bad I wish i could jump in a time machine and get the $2,000.00 back.
Today I left my PC on for almost 1 hour without the car running and my batteries were fine, I wouldnt recommend doing so, because in the end the battery will have to be replaced alot faster. Only reason I did it was because gas is so expensive and my car is a pig with gas. Once again it all depends on set up. If your system has a very small power consumption foot print, then your batteries will be able to run the PC longer.
PLANNING [100%]
CAR PC ITEMS [100%]
INSTALL OF PC [100%]
BUG WORKOUT [75%]
INTERIOR MODS [50%]
BUDGET [380%]
HiJackZX1 Work Log
HiJackZX1 is offline   Reply With Quote
Old 07-19-2008, 04:28 PM   #19
My Photos: (0)
I wound up buying the D945GCLF.
Hopefully it was the correct choice for my setup.
The power supply will be next, The only thing I hate is I need a supply for 12v.
and 1 for Ac.
I guess I'll have to buy 2 supplies?
For the 12v. I was thinking of this M2-ATX 160W Intelligent DC-DC PSU.
I won't have much to run off this supply, Just the board and a Dvd.
I don't guess this supply will contribute to draining the batts.
Calvin
Sponsored Links
vB code is On
Trackbacks are Off
Hard Drive Issues in a Vehicle Computer DarquePervert The FAQ Emporium 25 02-23-2008 01:35 PM
Hard drive dilema.... 2.5" or 3.5"? 3Tripnip General Hardware Discussion 2 01-14-2006 12:30 AM
Help!!! laptop hard drive ashbosh General Hardware Discussion 9 07-15-2005 01:34 PM
Laptop Hard Drive in carputer... Powers Newbie 7 05-08-2004 10:37 PM
Laptop Hard Drive Problems Powers General Hardware Discussion 0 04-28-2004 07:21 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
