The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Thread Tools Display Modes
Old 07-23-2008, 03:02 PM   #1
My Photos: (0)
Urgent!! Blue boxes all over my Lilliput! Help!!!
I fired up the 8" lilli for the first time in awhile, and there is a pattern of blue boxes ALL over top of the display!
I changed the vid card driver, and while the screen was flickering off and on, the display actually looked fine. But after the install finished, same thing...
Anyone know how to fix it?
WuNgUn is offline   Reply With Quote
Sponsored Links
Old 07-23-2008, 03:57 PM   #2
My Photos: (9)
Fired up for the first time in a while?
Meaning it's been used before right?
And it worked fine then?
Sorta looks like a screen protector film hahaha but Im sure thats not it
colin is offline   Reply With Quote
Old 07-23-2008, 04:16 PM   #3
My Photos: (0)
Yeah, worked fine before...before I opened it up.
Maybe something to do with Windows not recognizing it properly?
During POST, the screen is fine. It must have something to do with the Windows driver or settings...
Old 07-23-2008, 04:50 PM   #4
FPeter's CarPC Specs
FPeter's Avatar
Vehicle: 2005 / Opel / Astra H Z17DTL
My Photos: (7)
check the cable connections inside, i think there should be the problem
Intel D201GLY, 512MB DDR2, Maxtor 3.5" 40/7200/2M HDD, audio through digital line
bye bye noise - the DIY S/PDIF DAC
FPeter is offline   Reply With Quote
Old 07-23-2008, 06:32 PM   #5
My Photos: (0)
All cables and ribbons seem to be fine...
When I switch to 16 bit colour, the squares go bigger, and the colour of them changes to brown! WTF!!!
I change the res to 1024X768, and the boxes turn to solid, verticle bars...
Old 07-23-2008, 08:45 PM   #6
NiSlo's CarPC Specs
NiSlo's Avatar
Vehicle: 06 Impreza Hatch
My Photos: (16)
Try changine the refresh rate in your display properties.
If it's not the cables, it coudl be a sync issue.
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 07-24-2008, 01:03 AM   #7
AllShowNoGo's CarPC Specs
Vehicle: 1997 Pontiac Grand Prix GTP
My Photos: (0)
there should be a master reset on the lcd screen
1997 Grand Prix GTP - Pioneer Premier HU - Alpine 4ch for mids/highs - McIntosh separates in the rear (soon to be in front as well) - Custom Passive Xovers - Pioneer Class A 300wrms amp - 2.5 farad cap - The original RF "The Punch" Pro Series 12"
AllShowNoGo is offline   Reply With Quote
Old 07-24-2008, 05:26 AM   #8
FPeter's Avatar
My Photos: (7)
try to reconnect them, this problem is generated somewhere in the digital side of the LCD circuits...
Old 07-24-2008, 08:35 AM   #9
My Photos: (0)
Tried different refresh rates...56Hz all the way up to 75Hz. No change...
Resetting the settings makes no difference either...
I'm actually doing a clean Windows install on it, and whatever resolution/refresh Windows uses during setup, it's
much better, but still visible if you look hard enough.
It looks like the boxes are thinned and stretched out horizontally...but still visible.
I double checked all the connections. Every thing seems fine and undisturbed...
Old 07-24-2008, 10:19 AM   #10
My Photos: (0)
Jeez...$270 down the drain
Sponsored Links
Old 07-24-2008, 10:26 AM   #11
FPeter's Avatar
My Photos: (7)
not only check, try to reconnect them! and clean the connection surfaces with alcohol
are there boxes during boot and BIOS setup screen too?
Old 07-24-2008, 10:35 AM   #12
My Photos: (0)
I've had some of them disconnected a few times...
I'll try cleaning them I guess.
Is this something anyone else has experienced before??
No boxes visible in BIOS setup (then again, screen is blue too), but I don't think they are visible on the POST screen and splash screen...
Actually, the only ribbon I've disconnected was to the button panel...but I'll clean 'em all.
Old 07-24-2008, 11:01 AM   #13
My Photos: (0)
Well, I feel like bit of a newb now...
I tried the touch screen on my main PC and low-and-behold, the image is perfectly fine...
It's obviously my videocard in the carPC. Duh!!
Now to check the slot on it...
Sponsored Links
vB code is On
Trackbacks are Off
*NEW* USB Input/Output Board -- Fusion Brain 2k1Toaster Fusion Brain 1095 08-04-2008 01:22 PM
****Celica Carbon Fiber Car Computer Finished**** hombredelassrta Show off your project 47 09-02-2006 02:22 PM
BLUE SCREEN on my MONITOR!! WHATS THAT MEAN??? ironic General Hardware Discussion 2 08-05-2006 02:24 PM
Media Car not responding... Lilliput problem? carpcnoobie MediaCar 3 09-01-2004 01:38 PM
Lilliput 7" TS into TM-701L casing install problems :( NS98GSR LCD/Display 5 04-01-2004 04:37 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
