Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-09-2008, 03:09 PM   #151
overlander's Avatar
overlander is an unknown quantity at this point
Quote: Originally Posted by DarkSlice View Post
been along time since i did my carputer install (think 4/5 years have passed)
but i would like to upgrade the system now.
Can anyone confirm this line up?
Intel D945GCLF2 Dual-Core Atom
http://store.mp3car.com/ProductDetai...-0001&CartID=1
M2-ATX
http://store.mp3car.com/ProductDetai...R-015&CartID=3
Power Cable convertor (needed for D945GCLF2 )
http://store.mp3car.com/ProductDetai...L-056&CartID=2
1GB of DDR2 RAM
http://store.mp3car.com/1GB_DDR2_SOD..._p/mem-015.htm
My D945GCLF2 just arrived today and installing tonight. It's replacing my jetway C7. I have the M2 and using 1GB DDR. will post how it goes.
overlander is offline   Reply With Quote
Old 10-09-2008, 10:00 PM   #152
crooper's Avatar
crooper is an unknown quantity at this point
Yeah I picked up a 1 gig DDR2 667 Crucial from Newegg because it was the cheapest (like $17 with free shipping). Just ordered a 4th gen Mo-Co-So case. They said that they'll be in stock in 7-10 days. I've got a Seagate 120 gig 2.5 and M2-ATX from my last CarPC build. So far I've only checked the board to make sure it POSTs.
One issue is that the M2-ATX includes a 20 pin power plug and the board requires a 24 pin. I'm going to have to splice a 24 pin plug on there, and also create a P4 to P4 wire.
crooper is offline   Reply With Quote
Old 10-10-2008, 01:26 AM   #153
Woofnstuff's Avatar
Woofnstuff is an unknown quantity at this point
na, you just plug into the first 20 pins on the m/b and leave the last 4 empty.
have a look thru the paperwork that comes with the board, it shows you that in there too
Woofnstuff is offline   Reply With Quote
Old 10-10-2008, 01:42 AM   #154
fabworks is an unknown quantity at this point
I wouldn't replace the C7 for this board. The C7 boots like 5-6 seconds faster then this board.
The BIOS of this board loads dog slow even after disabling all the non-needed devices in the BIOS. Resuming from Hibernation is much slower then the C7 as well. The C7 comes out of hibernation in about 15seconds and the Intel board in 21+ seconds.
fabworks is offline   Reply With Quote
Old 10-10-2008, 01:45 AM   #155
Akrasiel is an unknown quantity at this point
i was planning to buy this mb to replace my jetway c7, what do you think about boot times? Are they really so slow?
Akrasiel is offline   Reply With Quote
Old 10-10-2008, 06:14 AM   #156
Woofnstuff's Avatar
mine it takes 8 seconds before i start to see the windows Xp booting screen
Old 10-10-2008, 01:28 PM   #157
On my Jetway it takes about 4-5 seconds, have you tried with bios update??
I got a long time boot in the past with my mb, but i solved the problem updating bios...
I can't believe that a so wonderful motherboard like D945GCLF2 gives this problem, because for me is a problem, i've passed days and days trying to get fast boot times :/
Old 10-10-2008, 05:15 PM   #158
Again, using hibernation and disabling all non-needed items in the BIOS of both boards and using a fresh OS install, the C7 beats this board by 5-6 seconds. Def. this is a problem with me and will not change my C7 for it.
This board would be perfect if it booted with the same speed as the C7 or better.
I measured boot time from the time the cpu fan starts to when the Front End is fully loaded and active.
Old 10-10-2008, 11:19 PM   #159
crooper's Avatar
Wow that rocks.... what I get for not RTFM.
Old 10-11-2008, 12:34 AM   #160
borikru is an unknown quantity at this point
Quote: Originally Posted by borikru View Post
Someone was asking about sound on D945GCLF
When I first got it it was connected to 2 channel amplifier and everything worked well.
Then i decided to use 4-channel capability and configured appropriately in the software. Now line-in on the back of the board should be connected to rear speakers. When I restarted CPC I heard strong noise coming from rear speakers which lasted until PC booted (probably until Audio driver was loaded). Also, when driving later I noticed very silent but still noticeable whining noise that did not exist before.
I spent few hours researching noise/whining related posts and then even more hours trying out some possible solutions like rerouting wires, grounding CPC chassis, moving grounding point to what seemed to be a better location - nothing helped.
I guess there is something wrong with this blue input/output jack that is used as rear output in 4-channel mode. It produces noise till the driver is loaded like if "line-in" is the default mode and is switched to rear spk output mode only when driver is loaded (same noise reproduced when switching to 2-channel mode with rear speakers connected to line-in jack).
If anyone knows a solution, I'd be glad to hear about it. Meanwhile, I just reverted back to using 2-channel mode and connected rear and front speakers to the amp to same jack from CPC (regular "green" spk output).
No complaints about other components, very nice mb wrt performance.
Intel support just confirmed that the noise from the blue jack configured as rear speaker out in 4 channel mode (line-in in normal mode) during boot (or return from hibernate) is expected behavior. So if anyone was planning to use this MB in 4 channel mode - not a right choice, unless you do not mind hearing strong noise for 2-3 seconds during boot and constant static noise (sounds like HD noise - probably bad internal shielding, grounding the chassis will not help probably).
borikru is offline   Reply With Quote
Old 10-11-2008, 03:21 AM   #161
NiSlo's Avatar
NiSlo is an unknown quantity at this point
I'm using 4 channels in my setup and I've not got any of the noise while booting...
I installed my carpc into my pet Kangaroo, mate.
NiSlo is offline   Reply With Quote
Old 10-11-2008, 05:30 AM   #162
anupchavda is an unknown quantity at this point
i have this board (it replaced my C7) and i can't be more happier with it. I too am not suffering from the 4 channel noise that other people are reporting.
anupchavda is offline   Reply With Quote
Old 10-11-2008, 08:07 PM   #163
Archy88 is an unknown quantity at this point
I certainly plan on going the 4-channel route with a car pc in the nearby future. If it were to install a soundblaster card, would this resolve the 2-3 sec of noise, and constant whining?
Thanks!!
Archy88 is offline   Reply With Quote
Old 10-11-2008, 08:14 PM   #164
BlackStealth is on a distinguished road
Why not use a serial port to turn on/off the Amp, this way you won't hear any noises when Windows XP boots and initializes the audio?
BlackStealth is offline   Reply With Quote
Old 10-11-2008, 08:37 PM   #165
Thanks for the suggestion Blackstealth!
That would certainly be a cheaper option, however I don't believe that would solve the constant sound that some people are hearing. Along with my current subwoofers, I plan on upgrading the factory speakers so I really want the best possible solution. I would hate to spend all that money & for the factory sound to come out better.
I have a SB Audigy 2z(s?) Platinum blah blah in my current PC. I would certainly get alot more use out of it with the carPC if needbe. Although, I don't know if it would fit the mini-itx. hmmm...
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Core Duo/Core 2 Duo processors RedGTiVR6 General Hardware Discussion 42 02-06-2007 09:00 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 03:56 PM
