Quote: Originally Posted by
upspace
and how do i plug power with it - still 20 pin plus 4 pin dc connectors?
I was doing some research on this board before I even saw this thread so, nice any timely!
I'm clear on hooking up power to the 20-Pin connector but, yeah, what's up with the additional 4-Pin DC connector? Is this something you can use instead of the 20-Pin connector? You have to hook things up to in addtion to the 20-Pin connector?
I'm switching from an AOpen board, which only requires +12V and Gnd to this so, I know I'm changing power supplies. I just want to make sure I've got everything I need when I order.
EDIT -
Found my answer in the technical documentation. For those that care, here's the answer:
The board has power supply connectors:
• Main power – a 2 x 12 connector. This connector is compatible with 2 x 10
connectors previously used on Intel Desktop boards. The board supports the use
of ATX12V power supplies with either 2 x 10 or 2 x 12 main power cables. When
using a power supply with a 2 x 10 main power cable, attach that cable on the
rightmost pins of the main power connector, leaving pins 11, 12, 23, and 24
unconnected.
• Processor core power – a 2 x 2 connector. This connector provides power
directly to the processor voltage regulator and must always be used. Failure to do
so will prevent the board from booting.
