Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-28-2009, 09:05 PM   #631
kapone is an unknown quantity at this point
Quote: Originally Posted by timebandit View Post
Hey guys,
This question is not really following the question, but it fits under this thread... I was wondering if anyone knew what the power consumption of the D945GCLF2 is when its in S3 standby mode? Also, if anyone is running it in S3 standby mode with the M2-ATX PSU?
Thanks..
Aye Aye to both (S3 and M2-atx).
Last time I measured, it was less than 50mA in S3 sleep.
kapone is offline   Reply With Quote
Old 10-29-2009, 06:10 AM   #632
Sinobi is an unknown quantity at this point
In the link it says OPTIONAL EXTRA about the cable,
and when I bought the M2-ATX from CarTFT I didn't get that cable along. Had to make it myself from som old PSU cables....works a charm.
Henrik
Sinobi is offline   Reply With Quote
Old 11-07-2009, 08:35 AM   #633
vull's Avatar
vull is an unknown quantity at this point
i'll probably need to buy it separately then..
P.S. any comments on this?
http://www.mp3car.com/vbulletin/revi...ml#post1352074
should i buy 667 or 533mhz memory?
vull is offline   Reply With Quote
Old 11-07-2009, 08:41 AM   #634
From the second post in your link, I would guess 667.
But I could be wrong though so check the post.
Henrik
Old 11-08-2009, 08:13 PM   #635
inspironee is an unknown quantity at this point
Quote: Originally Posted by dschu View Post
Hi,
Initially I couldn't find the composite signal either, but that was because I used the S-Video signals a few moments earlier - i.e. before you boot XP, you must decide whether you want to use composite or S-Video. You can't switch between them (whilst XP is running) or use both at the same time.
So this is the pinout for the composite signal I used (view of the back panel):
Code:
* = Ground
* = Composite signal
Hi dschu,
Where did you get a s-video cable with the correct pin-out to extract the composite signal?
inspironee is offline   Reply With Quote
Old 11-13-2009, 08:47 AM   #636
Spawn12336's Avatar
Spawn12336 is on a distinguished road
I just bought this board for the release of CF3, and I can tell you that after installing Win7 that the intel driver package supports multi-monitor. I reformatted as I like the hibernation and startup time better compared to Win7, and lo and behold, the freaking xp driver only does clone... poop!
I'm giong to rebuild again tonight and try not installing the intel driver as was stated previous in this thread. One question though, for those that have it working in XP, what are your video configuration settings in the BIOS?
"the universe has a way of balancing itself"
http://i15.photobucket.com/albums/a3.../Webbanner.jpg
Spawn12336 is offline   Reply With Quote
Old 11-13-2009, 01:53 PM   #637
txspazz's Avatar
txspazz is an unknown quantity at this point
multi-monitor With Win 7 is good to hear. I installed Win 7 a couple weeks ago, had everything setup, did one last restart and the board stuck like I had had issues with in the beginning (fan turns on when the power supply turns on and that is it). Just got an RMA from Intell.
txspazz is offline   Reply With Quote
Old 11-14-2009, 02:12 PM   #638
ctec is an unknown quantity at this point
Unhappy Corrupted Bios ?
Hey guys. I have a problem with my board. when i turn it on the fan spins and keeps spining and the green light on the motherboard light up butt nothing comes on the display. After searching on internet i found out that maybe the bios is corrupted due to some reasons. I followed the steps to recover corrupted bios with a usb and a .bio file without any success.
I want to ask you guys if someone can help me.
ctec is offline   Reply With Quote
Advertisement Sponsored links
Old 11-14-2009, 02:43 PM   #639
Spawn12336's Avatar
Only issue I am having now is that the VGA drops for a second and everything moves to the lower monitor (s-video) then switches back. It gets pretty annoying to be honest. It might be my vga splitter (run a second monitor on a dj stand for car shows), so I am going to run it straight to the monitor and see what happens.
Old 11-14-2009, 11:26 PM   #640
theonlykid is on a distinguished road
It is 1 of 2 things and neither one is a corrupt BIOS.
#1 you don't have the P4 connected to the board to provide power to the CPU
#2 If you are using the P4 you have a bad board. We have gone through a ton of these boards with a relatively low failure rate. However the top failure is exactly what you are describing. I have no idea what the weak point on the board, but there is something in the design that when it fails the video goes out but the green light comes on and fans still spin.
theonlykid is offline   Reply With Quote
Old 11-15-2009, 12:56 AM   #641
hexxamillion's Avatar
hexxamillion is on a distinguished road
I agree regarding the P4 connection. Make sure that you have it connected..silly but simple.
"Live Free!!!...It's all about Open Source"
Worklog: '05 Nissan Altima Project (Intel D945GCLF2D)
Project #2:Solar Power Integration
Vimeo Vids:Project Videos
Blog: Hexxamillion.com- 100% Powered by Wind Energy
Twitter:http://twitter.com/hexxamillion
hexxamillion is offline   Reply With Quote
Old 11-15-2009, 03:58 PM   #642
txspazz's Avatar
Yes, P4 was connected. It went from running - shut down - attempted restart and no more working. Tried different PSU, pulling memory. I let it sit with the battery out and disconnected from the power supply for a week as that had worked once in the past, but no dice this time. Intel didn't give me any flack over it. I talked to 'em once and they said try resetting the BIOS and if that didn't work get back with them and they would get me a new one.
Old 11-15-2009, 07:13 PM   #643
Spawn12336's Avatar
My issue is solved with the dual monitors now. It was the vga splitter I was using, I'm assuming that it was having power fluctuations as it was powered via the car's 12 volt. I'm going to try to macgyver a connection to the OPUS over the winter (thankfully no shows until April at the earliest).
Old 11-15-2009, 09:39 PM   #644
Deric's Avatar
Deric is an unknown quantity at this point
I had the same problem as you. One day booted just fine and then the next nothing but green light and fans without POST. I had to RMA my board. I also had issues with the board booting with my Opus. I had to manually power on the board to get it to work. After my RMA all was good.
2006 Mustang with indash CarPC
Parts list
D945GCLF22GB RAM20GB HDD
Opus 120W PSULilliput 8"Directed HD
RideRunnernLite XPiGO8
Deric is offline   Reply With Quote
Old 11-20-2009, 11:13 PM   #645
Someone from the store where i usually buy this stuff told me that the bios can be damaged due to tempratue and humidity. What do you guys say about that.
What are the temp range for this mobo ?
Is it possible that in winter ( As the guy said ) it will be a problem to use it ?
I bought a new one, D945GCLF2D.
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Core Duo/Core 2 Duo processors RedGTiVR6 General Hardware Discussion 42 02-06-2007 09:00 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 03:56 PM
