Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-22-2008, 09:55 AM   #1
nobb will become famous soon enoughnobb will become famous soon enough
Low power consumption 24/7 video recorder?
I was wondering if there exists a video device that could record 24/7 but draw very little power? Would also be nice if the device could automatically delete older footage to make room for new footage...thereby making the device practically maintenance free. Hopefully can store atleast a day worth of video.
I could easily rig up the carpc to do this, but the high power consumption makes it unfeasible for 24/7 operation.
What do you guys think?
nobb is offline   Reply With Quote
Old 09-04-2008, 11:20 AM   #2
Bump...ok maybe ill lower my expectations a bit.
I dont necessarily need a 24/7 device, but maybe something that draws under 10watts that I can leave recording for 8-10hrs a day while I am at school.
Old 09-04-2008, 11:58 AM   #3
Raw Wave
shotgunefx's Avatar
shotgunefx is on a distinguished road
When i had looked into it in the past, I saw some flash bashed DVRs on ebay that weren't horrendously expensive.
shotgunefx is offline   Reply With Quote
Old 09-04-2008, 10:57 PM   #4
blackcobra487 is an unknown quantity at this point
What I would look into is something like a spycam. They make some now that use memory cards and write straight to the card. Usually, they're hidden in things like a clock, but you could take the circuitry out and do as you wish with it. Something like this:
http://cgi.ebay.com/ebaymotors/Motio...QQcmdZViewItem
blackcobra487 is offline   Reply With Quote
Old 09-04-2008, 11:13 PM   #5
Raw Wave
shotgunefx's Avatar
This looks promising except for the record length
http://www.4hiddenspycameras.com/podivire2tft.html
Portable Digital Video Recorder 2.4" TFT Monitor (Schedule Recorder & Overwrite)
Rechargeable battery Powers the covert camera direct using the same power and rechargeable battery built inside, stamps date and time, schedule recording system (Time and date) , supports 4GB SD memory card for 3.5hrs of video recording time, 2.4 TFT color monitor, resolution VGA 30fps real time recording, Compression MPEG-4 Format, PC interface (USB2.0) and more.
Specifications:
MINI Mobile Digital Video Recorder
SD/MMC. card slot (support up to 4GB)
date and time stamping
loop overwrite record or continuous record
Extend Interfaceirect supply DC Power 9V output for Camera and Video composite input
Special Power save button (monitor sleep mode)
Display : 2.5" LTPS TFT LCD 960x240,230K
AV recorder resolution : 640x480(VGA) / max 30 fps.
Adapter : 5V DC adapter (USB port) / USB cable
Dimension:95.5mm x 63.5 mm x 21 mm
Schedule record.
3 level of selectable recording timer from 1 minutes to 240 minutes (4 Hrs)
Overwrite.
Settings REC MODE Continuous ( REC loop duration that continuously overwrite records to SD data storage)
Standby
Settings power saving star time 2,5,10 min.
Old 09-04-2008, 11:18 PM   #6
Raw Wave
shotgunefx's Avatar
Here's another, a bit pricier, but 4channels and 300+ hours
Old 09-04-2008, 11:28 PM   #7
Thanks for the suggestions. I guess I have been using the wrong search terms on eBay all along. Ill keep looking and see if any of them suit me. I think the only features I really need are automatic write over and low power consumption.
Old 09-05-2008, 12:35 AM   #8
Ok so after a bunch of searching, I found this:
http://cgi.ebay.com/DVS-Digital-Vide...QQcmdZViewItem
Very cheap and even includes 2 night vision cameras. Also maintenance free since it automatically loops over old video. Might be difficult to hide the camera in the car though.
Any opinions on why I should not just go ahead and buy this?
Old 09-05-2008, 02:45 AM   #9
Raw Wave
shotgunefx's Avatar
Certainly cheap, I wonder how good the video quality is. 2GB isn't going to hold a lot.
Old 09-05-2008, 09:09 AM   #10
^Well it appears to be the same as this unit:
http://cgi.ebay.ca/USA-DVR-Camera-Vi...QQcmdZViewItem
Video resolution is 320 x 240 and picture resolution is 640 x 480, so I suspect it would probably be better to use automatic picture mode. Reading the specs on similar looking units on eBay, apparently the device can record 4380 videos. Each video is 10s, so doing the calculations, it means the device can store 12 hours of video. That should be more than enough because it only records when in motion.
Old 09-05-2008, 11:21 AM   #11
kwchan's Avatar
Location: Singapore - Smallest country in Southeast Asia
kwchan is an unknown quantity at this point
looking at something that can record in DIVX @ 30fps, preferably support >4GB SD card
The DVS can only record 8fps in AVI format
kwchan is offline   Reply With Quote
Old 09-05-2008, 08:03 PM   #12
Well, I couldnt find any better system that would meet my needs of low power consumption and automatic loop recording. So I just pulled the trigger and bought the sd dvr:
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=012
and a cctv camera (I hope those are real ir leds):
http://cgi.ebay.com/ws/eBayISAPI.dll...MEWN:IT&ih=018
Also bought some lm317 voltage regulators so that I can hook them up in the car. Total cost is just a little over $100CAD. The whole system should draw under 5 watts and will be run from my auxiliary deep cycle battery. Although having a high frame rate would be great, I think I will just set the system to automatically take pictures when there is motion. Hope this works.
Old 09-05-2008, 10:27 PM   #13
kwchan's Avatar
great...can post some sample video once u got it?
Old 09-05-2008, 10:41 PM   #14
Sure, if I remember. It's shipping from China...so will probably take a while.
Old 09-08-2008, 10:15 PM   #15
I was wondering if any electronic gurus would have a good recommendation to efficiently regulate the voltage from 12v to 9v and 5v to power the recorder and camera. I am most familiar with the lm317 chip, but that seems to dissipate the extra voltage as heat. I would prefer something as efficient as possible. Every watt counts, as I am running on battery.
New OBDII scantool - Beta testers? tmort Engine Management, OBD-II, Engine Diagnostics, etc. 173 01-08-2008 07:44 PM
My low cost, easy to build power supply... SkinnyBoy Power Supplies 52 09-27-2006 07:10 PM
onboard video vs a video card, power and cpu usage stapan General Hardware Discussion 2 06-09-2005 03:43 PM
Keeping Power Supply on 24/7 ? homep1 Power Supplies 2 06-07-2005 03:42 PM
Looking for low power 24/7 Bluetooth Capable Computer psuter General Hardware Discussion 2 03-28-2003 04:52 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
