Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-24-2008, 04:01 AM   #1
NSFW is an unknown quantity at this point
USB power limits
I'm trying to figure out if I should add a powered USB hub to my system, and I'd appreciate anyone's thoughts on this...
My CarPC is a laptop with two serial ports.
Port 1 goes to an unpowered 7-port USB hub, which connects to:
* Bluetooth radio
* OBD2 cable
* USB-to-serial cable
* Xenarc Touch-screen
* USB extension cable into the center console, mostly not used, sometimes used for a flash drive.
Port 2 goes to an unpowered 4-port hub, which connects to:
* W3bm4st3r auto-on module (there's a relay that it drives)
* WiFi radio
* GPS radio
At some point I should have a powered USB hub in my car, just for the sake of power draw, and I'm a little concerned that might be at or beyond that point now. Most of this stuff draws very little power, but I'm a little concerned about the Bluetooth and Wi-Fi antennas since they can warm up pretty good when in use.
Anyone care to speculate on whether I should get power to those hubs?
Thanks!
NSFW is offline   Reply With Quote
Old 08-24-2008, 04:12 AM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Bluetooth, WiFi, and GPS are all big power users. I dont know about the auto-on, but a relay can take 400mA easily depending on the size (or it could take 50mA again depends).
I think you have actually surpassed the cutoff for getting a powered hub.
Since it is a laptop, you cant even distribute the usb to not overload any root since the laptop only has 1 root (driver, not physical ports).
I say get a powered hub. Or at the least, some of those car chargers for mp3 players/cell phones that have a USB port on the other end so you can splice power off of that, and data through the unpowered hub as normal. And keep in mind the hub itself does use a little power.
Old 08-24-2008, 05:59 AM   #3
bes51659's Avatar
bes51659 is on a distinguished road
Why is most hubs 4 ports?
It's because every device is allowed to comsume 100mA and request 500mA from its hub (if passive). So a hub (in itself a device) request 500mA, uses 100mA itself and remainder goes to its four ports.
A 7 port is like two 4 port hubs in chain, so there are no passive 7 port hubs. If you want to be within spec, and I think you do, considering all sorts of problems you might have with USB in the car anyway, you'd better get a powersupply.
One more thing if you are wiring USB all over the car and have active hubs: You can cut the USB cable open, leaving just the data wires. That will ensure no ground loops and data traffic is less subseptive to noise.
I run into an active hub that returned 5V from its supply to the PC, which is a no-no. Cutting the power will for sure prevent that.
5V DCDC is not cheap, and you need to be able to turn them off or you will drain your battery. There is a clever device that will be turned on and off depending on presens of 5V on its USB input.
A 8051 system that controls PC power etc with or without BMW IBus and is a GPS receiver with dead reckoning. mp3car thread
My car installation mp3car thread "showing off project"
bes51659 is offline   Reply With Quote
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
W3bMa5t3r's USB Power Modules W3bMa5t3r Power Supplies 41 12-07-2008 12:44 PM
QUESTION about M2-160WATT AND X-TREME CARPC kostas_lion Power Supplies 3 05-15-2008 10:50 AM
Another USB standby idea: splice wire and use a relay?..need help S4Per General Hardware Discussion 4 11-04-2006 11:12 AM
USB power issues - opinions please zaxxon Power Supplies 2 07-20-2005 11:03 PM
