11-25-2008, 07:08 PM
#1
Awesome new 3.5" board w/ C2D, DDR3, X4500, ALC888...
Just saw this one and thought people here may be interested:
Form Factor
3.5" Miniboard (146 x 101 mm)
CPU
Intel® Core 2 Duo with Socket P @ 667/800/1066 MHz FSB
Memory
1 x DDR3 SO DIMM support 800/1066 MHz up to 2.0 GB
Chipset
Intel® GM45 & ICH9M
Real Time Clock
Chipset integrated RTC with onboard lithium battery
Watchdog Timer
Generates a system reset internal timer for 1sec/min ~ 255 sec/min
Power Management
ACPI 2.0 compliant, supports power saving mode
VGA Interface
Intel® GM45 integrated GMA X4500 Technology
LVDS Interface 24-bit dual channel LVDS interface Serial ATA Interface
2 x Serial ATA II Interface with 300 MB/s transfer rate.
Audio Interface
Realtek ALC888 HD Audio LAN Interface
2 x Intel® 82574L Gigabit Ethernet
GPIO Interface
Onboard programmable 8-bit digital I/O interface
Extend Interface
Min-PCI and PCI Express Mini card sockets
External I/O Port
2 x RJ45 LAN , 1 x SPDIF , 1 x PS/2 Keyboard / Mouse , 1 x VGA , 1 x COM
Internal I/O Port 1 x RS232/422/485, 1 x SMBUS, 1 x IrDA , 4 x USB 2.0,
1 x 8-bit GPIO, 1 x Audio, 1 x CDIN, LVDS and LCD inverter
connector, 1 x HDTV
Power Requirement
DC 12V input
Board Dimension 146mm x 101mm (L x W) Operation Temperature
0 ~ 60ºC (32 ~ 140ºF)
Commell LS-373
http://www.commell.com.tw/Product/SBC/LS-373.HTM
Looks pretty sweet to me...may have to replace my LS-372...
2006 Lancer Evolution IX MR In-Dash PC Project - WIP
Planning:
[----------] 100%
Purchasing:
[----------] 90%
Installation/Fab/Assembly (Revised v2):
[----------] 90%
11-25-2008, 08:47 PM
#2
wow nice board now i have another option instead of the intel board
11-25-2008, 09:09 PM
#4
i think more than 4 usb would be better than 2 x GIG lan ports
guessing its been designed with server firewall solutions in mind
Injector, that toslink to 3.5mm adapter cable.. its still an optical cable, just some plug types use the 3.5mm hole for optical in/out
11-25-2008, 09:37 PM
#6
Quote: Originally Posted by Injector
only optical toslink for audio
It has a header on the board for audio, which I presume would give you all the normal analog input/outputs. It has a Realtek HD Audio ALC888 codec, which is quite good.
Also, no one mentioned this:
Quote:
GPIO Interface
Basically a built-in Fusion Brain! Albeit digital only, no analog. But still, very useful.
This board looks very interesting.
-- Kevin
11-25-2008, 09:44 PM
#7
Hi galvitron, do you know of a compact DC-DC power supply board that has just a 4-wire 12V output?
I've been looking for one for some time, and the best seems to be Liantec: ...but try finding one anywhere...
All the DC-DC boards seem to have 20 or 24-pin...
If you are going to spend the extra money on a compact 3.5" board it seems sensible to find equally compact peripherals...
11-25-2008, 09:45 PM
#8
The board has standard stereo headphone style jacks for stereo output via headers that go to a little mountable jack assembly about 2 inches wide.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
#9
any idea on the price at all or when its available as i cant really find it much elsewhere
11-25-2008, 09:47 PM
#10
^^ That unit actually looks good. I have something similar, the DSX12VD
http://store.mp3car.com/DSX12VD_140W..._p/pwr-025.htm
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
11-25-2008, 09:49 PM
#11
Here is their U.S. distributor:
http://www.globalamericaninc.com/p33...duct_info.html
EDIT: Also, expect it to be around $400 USD.
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
11-25-2008, 10:06 PM
#12
Quote: Originally Posted by galvitron
holy crap batman not worth it for that price. That isnt even with a CPU
11-25-2008, 10:16 PM
#13
It is expensive, but can't be beat as far as size/performance
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
11-25-2008, 11:14 PM
#14
11-25-2008, 11:40 PM
#15
^^ That's nice, but a Core 2 Duo is much more powerful. (not trying to be mean)
Planning:
[----------] 100%
Purchasing:
[----------] 90%
[----------] 90%
| Thread Tools |
| Display Modes |
Linear Mode
| Thread |
Thread Starter |
Forum |
Replies |
Last Post |
Gene 6320, 3.5" Board
sewy |
General Hardware Discussion |
0 |
03-01-2005 03:10 PM |
