Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 02-11-2003, 12:43 PM   #1
Registered User
dead hard drive...
Does any one know about reviving dead hard drives?
Situation:
I have this 40 gb hd that I was installing win98 on, it originally had xp on it but was changing converting it for a different pc project. I formatted the drive and then started the install process. After getting the drive completly setup with win98 I restarted the pc and screen came up with non system disk. i checked the drive with fdisk and the drive is still there but it can't recieve a format in dos7 or on other windows machines.
any help would greatful.
tapper1999 is offline   Reply With Quote
Old 02-11-2003, 12:47 PM   #2
Registered User
contact the manufacturer and get an rma to send it back. They'll send you a new drive, sometimes even better one. Ive done this with several drives and all turned out well in the end. As far as reviving the one you have, I wouldnt mess with it, not worth it.
The Grand aMP3 Project
Car: 96 Pontiac Grand Am
Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
grandamp3 is offline   Reply With Quote
Old 02-11-2003, 01:01 PM   #3
GRUNT's Avatar
If you can see the partitions from Fdisk.
The drive should be ok??
I had a problem with converting a disk from Linux to dos.
I could make the partitions, but could not boot, it would still find
the Linux boot info.
I use from DOS Fdisk /MBR.
See if that works for you.
John
GRUNT is offline   Reply With Quote
Old 02-11-2003, 01:36 PM   #4
Super Moderator
hijinks21's Avatar
here is a great tip an old tech guy gave to me. Place the drive into the freezer for like 20-30 minutes. Take it out.. let it sit for about 5 then use it. You might get like 30 minutes to an hour of working time. I'd say that's your last resort though. It has worked for me.
'98 Explorer Sport
80% done
hijinks21 is offline   Reply With Quote
Old 02-11-2003, 04:47 PM   #5
CA 3000GT's Avatar
Whoa!
Dont put that disk in the freezer quite yet!
(thats a cool tip though... Im gonna remember that in case I hear of a drive dying... do you know how that works in terms of hardware? I mean, if the heads have crashed into the platter... how could freezing help... though I think I have heard mention of that technique before someplace.... )
We got 2 situations here
1) Disk heads crashed into the platter, this is how disks typically "die", you will often hear a grinding noise on these disks..
2) Incorrectly formated/partitioned disk, I think this is what you have... Im gonna guess that in the install process, some essential part of the file system was overwritten..
I would try re partitioning the disk, then re format it.... perhaps attach it to another win98 machine to do that... or win98 programs to do it.
best of luck
1995 SL stock
Working On: GMAT
Given Up On: Custom motorized lcd
CA 3000GT is offline   Reply With Quote
Old 02-12-2003, 02:30 AM   #6
Registered User
Raas's Avatar
maybe the disk is in NTFS instead of FAT32 and that's why you can't see it in DOS ????
just shooting possibilities here
Greetz,
Raas - The Netherlands
ME: VIA epia m10000, lilliput 7', opus 150w, 80gb<br>
GF: IBM Thinkpad 380, ext. 3.5 80gb, 40x4, PB-IR
Raas is offline   Reply With Quote
Old 02-12-2003, 07:40 AM   #7
regarding the freezer, usually how this works is if the spindle mechanism has seized, the cold lets everything contract to the point that the drive can spin up again. obviously, this does not work in all situations (dead electronics, physical crash).
jstrain is offline   Reply With Quote
Old 02-12-2003, 08:16 AM   #8
Retired Admin
Aaron Cake's Avatar
Has anyone who answered even worked on a computer before? Obviously not, since you don't know even the basics of logical throubleshooting. We need a LOT more information before we can recommend an action.
FIRST, ignore all advice in this thread except for CA 3000GT.
Second, run FDISK and delete all partitions. Then create a primary DOS partition, reboot with a boot disk in the drive, then FORMAT C: /S. After the format goes through (did it try to "recover allocation units"? if so, you have a bad drive) reboot without your boost disk. Should dump you at a C prompt. Now go about reinstalling Win98.
Note that this will completely erase the disk.
Aaron Cake is offline   Reply With Quote
Old 02-12-2003, 11:27 AM   #9
MP3DUB's Avatar
But if cant see any partitions (ntfs/hfs/linux) fdisk /mbr will delete the master boot record and any possible partitions, and then fdisk to create partitions and then format. also, the thing that no one else has asked is physical connections and bios configuration. is everything in snugly? does bios see the hd? is it set to boot from the hd? (not lan or cd or floppy).
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 02-12-2003, 11:51 AM   #10
ddt
Registered User
ddt's Avatar
yeah, really! I had this happen before. I switched out the IDE cable and all was well.
Don't start with drastic measures. Work your way there.
ddt is offline   Reply With Quote
Old 02-13-2003, 08:10 AM   #11
Retired Admin
Aaron Cake's Avatar
FDISK /MBR does NOT destroy all partitions. It only rewrites the master boot record. Normally, this is safe. However, if the partition table is bad, then it may accidentally destroy the partitions.
If the BIOS can see the drive, and it doesn't have any bad sectors and is spinning, then you are looking at a logical problem, not a physical problem.
Old 02-13-2003, 01:55 PM   #12
MP3DUB's Avatar
It does effectively delete the partitions, as the mbr contains the partition information. If you mean that it doesnt zero out the entire hd, this is true. You could also get a "low level format" tool from your hd manufacturer and try that (and no, the "low level format" utities don't really low level format anymore, they just zero the drive).
-Nick
Old 02-13-2003, 03:04 PM   #13
Raw Wave
Rob Withey's Avatar
No it doesn't:
http://support.microsoft.com/default...B;en-us;q69013
"Fdisk has an undocumented parameter called /mbr that causes it to write the master boot record to the hard disk without altering the partition table information."
Rob
6yr old first install died 20/8/2005 as result of bad bios flash.
New system : 6x5x2" contains 1GHz C3 PCM9373, ISR based PSU, 8Gb flash DOM, 98Lite, DirectShow based frontend.
GPS : Rikaline 6010.
Display : LTM08C351 + LVDS receiver.
Rob Withey is offline   Reply With Quote
Old 02-13-2003, 06:23 PM   #14
Registered User
I used the fdisk /mbr method. When i did this the partitions were saved. Now that I think of it this drive was a linux hd before. Everything is good now.
Old 02-14-2003, 08:38 AM   #15
Retired Admin
Aaron Cake's Avatar
See, told you.
