Go Back   MP3Car.com > Mp3Car Technical Hardware > General Hardware Discussion
Old 01-20-2009, 05:18 PM   #1
Ludercrs is an unknown quantity at this point
Looking for Buttons (maybe with USB?)
I'm trying to find some buttons i can use with my CarPuter mainly as a Next/Previous for Winamp but i can't find anything that's either US or Com Port with 2 buttons. I've looked at Phidgets also but they don't have any buttons either just a knob that can be a button but hat's not what i want. (besides i want 2 side by side)
does anyone have any ideas of something out there available that could fit this demand?
Ludercrs is offline   Reply With Quote
Old 01-20-2009, 05:28 PM   #2
bratnetwork's Avatar
bratnetwork is an unknown quantity at this point
you could just get 2 standard buttons or a panel that has 2 buttons in it and connect that to a Fusion Brain and have the software send whatever key it is that you need to get winamp to next/prev. could be a little involved, but really its not that difficult.
bratnetwork is offline   Reply With Quote
Old 01-20-2009, 06:03 PM   #3
ok, I see what you mean by fusion brain but where would i get buttons that connect to that?
Old 01-20-2009, 06:21 PM   #4
any standard automotive momentary button from you local auto parts store or radio shack. the software that comes with the unit is fully programmable and customizable so you would hook the switch up to one of the analogue inputs and tell the program that when the input sees voltage to execute the next / prev command
Old 01-20-2009, 06:27 PM   #5
so I can use buttons that are already in my car? just hook up the power/ground to the board?
Old 01-20-2009, 06:31 PM   #6
mayhembdm666's Avatar
mayhembdm666 is an unknown quantity at this point
If you have a spare PS2 keyboard laying around and your computer has the free port to use it or have a USB keyboard around.
Simple remove the cable and main interface card from the case of the keyboard and follow the two wire/circuit lines that run from the keys "Z" and "B" and wire two switches to them both.
Then all you need todo is find a switch that fits the looks and style you like. From radioshack/jaycar/dse/online.
This method works perfect and simply is the same as pressing a key on the keyboard
have a look at: Keyboard Hack
2004 Holden WL Caprice Auto 5.7L
System currently being planned.... Progress Around 40%
mayhembdm666 is offline   Reply With Quote
Old 01-20-2009, 06:35 PM   #7
the brain will have 3 pins in the header you connect to. one is 5v+ one is ground and one is 5v input - you would just run a wire from the 5v+ to the button of your choice then out the other side of the switch to the 5v input of the brain
To understand how it works in more detail checkout their website and their section of the forum
Old 01-20-2009, 07:05 PM   #8
ya i understand how the brain works i just don't know what would connect to it. I was expecting stuff made to connect to it and not stuff i have to McGuyver.
Old 01-20-2009, 07:26 PM   #9
Fusion Brain Creator
greenman100 is on a distinguished road
You don't have to macguyver. Any switch will work. We didn't make switches, because everyone has different taste. Just pick up a switch, and one of our three pin cables.
greenman100 is offline   Reply With Quote
Old 01-20-2009, 07:31 PM   #10
Im sorry to ask, But why would you go with the fusion option as this will would require alot of work.
Using something like the keyboard hack is fool proof and fault proof along with u can simple use the default keystrokes for winamp and build a whole control panel and still have your fusion system available for more complex setups?
Old 01-20-2009, 09:31 PM   #11
navmaxlp is an unknown quantity at this point
Don't know if this will help or not but over at www.byoac.com they have a keybpard emulator for home brew arcade machines (addicting let me tell you). Anyhow, this is the one I use:
http://www.ultimarc.com/ipac1.html
It plugs in between your keyboard and computer and you can map keys for the buttons to emulate. Nice thing is you can use any kind of switch you like once it's connected.
Theres a wealth of info at byoac about switches too. Just cruise around a bit and you can find different kinds of switches. I warn you though, much like carputers this can be a bit of a black hole from whence you may not be able to return.
Hope that helps some.
navmaxlp is offline   Reply With Quote
Old 01-21-2009, 12:35 AM   #12
i dont want to use the keyboard hack cus the keys "z" and "b" are not what i want to use (and the keys won't work unless winamp is the active window)
i also don't really want my car to look like an arcade with those buttons lol.
all i'm looking for are actual buttons, yet everyone keeps saying "you can use any button" well then SHOW ME SOME.
Old 01-21-2009, 12:50 AM   #13
http://www.radioshack.com/family/ind...goryId=2032278
any of those
Old 01-21-2009, 01:15 AM   #14
Mod - iPad Forums
RipplingHurst's Avatar
RipplingHurst will become famous soon enough
More here:
http://www.electricalconnection.com/...h_high-amp.htm
And here:
http://www.thehoffmangroup.com/keepi...odinc=switches
RipplingHurst is offline   Reply With Quote
Old 01-21-2009, 09:33 AM   #15
and all of those are switches and not buttons.
Mini-ITX boards RedGTiVR6 General Hardware Discussion 120 06-26-2010 11:54 AM
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 152 12-29-2009 08:13 PM
Newbie build-up: Ampie CarPC EEEEeeee36 Newbie 56 03-28-2008 09:03 PM
Via Epia Mii10000 USB buurin General Hardware Discussion 19 07-22-2006 02:52 PM
Problem with ITPS / hibernation and External USB HD veetid Power Supplies 5 01-02-2006 08:35 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
