Pioneer Aux interface.... wiring up ... how?
OK
I've got a cd-rb20 pioneer interface and I'm just checking the wiring guide with my stereo's and I'm a bit confused.... (it is the right interface for my stereo btw)
The interface has three wires,
Black - for an earth - can do that one
Yellow and yellow......
The first yellow is to be connected to a constant 12V supply - which I assume I could wire to the yellow on the wiring harness for the stereo
to quote both install diagrams
Stereo - " yellow - to terminal always supplied with power regardless of ignition switch postion"
Interface - "yellow - to terminal always supplied with power regardless of ignition switch postion"
I take it I have a match there
Ok the other yellow just has a connector on it (one that something may or may not plug into)it has a "+battery output" label on it
To quote the interface instructions
Yellow " Connect to MultiCD unswitched power supply"
and the stereo instuctions..... nothing!
there is a thin black wire that goes from the head unit.. and the cd changer doesn't work without it... could this be an earth? Does unswitched power supply mean another constant supply? if so why does it need two constant supplies all the time.... I'm confused!!
Kenny
