Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-25-2009, 01:41 PM   #31
Super Moderator & Wal-Mart Greeter
Tidder's Avatar
Tidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant futureTidder has a brilliant future
It is very good, I just built a media center with a buddy of mine last night using one of these boards. So far, very impressed, but looking forward to reading some of you all's reviews.
Tidder
Try RevFE
The best frontend I've ever used, period.
Best Quote EVER!!
Quote: Originally Posted by bramlet View Post
I try to search but I usually only find posts where people ask questions and darquepervert tells them to search.
Tidder is offline   Reply With Quote
Old 06-25-2009, 06:09 PM   #32
licensed to kill
kev000's Avatar
kev000 will become famous soon enough
Can you use both video outputs (analog+HDMI) for dual display?
LinuxICE2 beta2 is released!!! get it now!
OpenICE - The Free infotainment platform.
Follow OpenICE development
kev000 is offline   Reply With Quote
Old 06-25-2009, 06:35 PM   #33
Blues is an unknown quantity at this point
Quote: Originally Posted by Punky View Post
finally a good looking replacement for the intel's ****ty buggy dual core atom.
Huh?
What do you mean by this? The Zotac Ion mothrboards still use Atom CPUs.
Either a dual core Atom N330 or a single core N230. But here just combined wit nVidia's new Ion chipset with GPU instead of using Intel's own chipset.
Blues is offline   Reply With Quote
Old 06-25-2009, 06:36 PM   #34
Tidder's Avatar
We'll test it and get back to you.
Tidder
Try RevFE
Best Quote EVER!!
Old 06-25-2009, 06:44 PM   #35
Zogg's Avatar
Zogg is on a distinguished road
I'm using the Zotac 630i mini-itx motherboard and a Celeron 430 35 watt cpu based on another recommendation I saw on this board. In the car it works great. Low power consumption, handles all the flash stuff with no problems, and I have the option to go to a dual core socket 775 if I ever need one.
I tried it in the house running some video stuff but the Geforce 7100 just doesn't quite have enough oomph to handle some of the H.264 video I threw at it. Could probably do it with a better cpu but I didn't try it. Transport Stream videos ran about 70% cpu utilization.
For just a little more than the Ion board you could get the Geforce 9300 based board and a low-end dual core cpu, which is what I'm thinking about for a media PC.
Carputer progress:
100% [▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓▓]
Zotac N630I-D-E M/B w/ Nvidia 7100, Celeron 430 1.8 GHz, Xenarc 700IDT, M2-ATX, RR & DFX 4.0.
Zogg is offline   Reply With Quote
Old 06-26-2009, 01:32 AM   #36
Punky is on a distinguished road
I'm not talking about the processor, i'm talking about the motherboard, intel has their own dual core atom mobo too, same processor, different bios and graphic chipset, its cheaper, but terribly buggy.
Quote: Originally Posted by Blues View Post
Huh?
Punky is offline   Reply With Quote
Old 06-26-2009, 10:11 AM   #37
jpinkerton's Avatar
jpinkerton is on a distinguished road
I've got the 630i WiFi version planned to go into the car, same processor as well. I'm just waiting on replacement PSU.
jpinkerton is offline   Reply With Quote
Old 06-27-2009, 12:40 AM   #38
Zogg's Avatar
What PSU are you going to use? I bought a PicoPSU 120 wide input and it worked okay for a couple of days, then refused to turn on reliably. Just see the LED flash momentarily and then nothing. This was with the Zotac, Celeron, and a 2.5" SATA drive, and nothing else. All current req.'s well below the limits on the PicoPSU. This combo works perfectly with an M1-ATX, which is a 90W supply. Got a replacement PicoPSU and it's even worse. I'm hoping to get a refund for the Pico since it's unusable.
I'm currently running the system off the M1-ATX, with a bastardized ATX extension cable hanging out of the case, which is too small for the M1. I have to run my display and HD-radio off car power, but at least the system works. It's all under the drivers seat so at least you can't see the wiring mess. Extremely disappointed with the PicoPSU though.
Carputer progress:
Old 06-27-2009, 12:47 AM   #39
jpinkerton's Avatar
I was planning to use the M4-ATX but due to some firmware issues causing my M4's not to power, I'm going to make the switch to the DSATX 220. It should be here Wednesday.
Old 06-27-2009, 01:45 PM   #40
Zogg's Avatar
What is the firmware issue and on which device? I'm wondering if it's the same problem I saw with the PicoPSU. Sometimes it would work but usually not.
Carputer progress:
Old 06-27-2009, 01:50 PM   #41
jpinkerton's Avatar
It was a firmware issue on a few select M4's - I just happened to get two of 'em with the issue.
Old 06-28-2009, 02:36 PM   #42
tempgp's Avatar
tempgp is an unknown quantity at this point
can some one confirm that Zotac MBs dont have issues with USB droping and freezing on bootup?
I'm looking at AMD based version but still afraid to test it
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 06-28-2009, 08:35 PM   #43
jpinkerton's Avatar
Cold boot or out of hibernation? Touchscreen works just fine on mine from both.
Old 06-28-2009, 09:18 PM   #44
tempgp's Avatar
how many USB devise u have
I had too much trouble with USB Deives on few oter boards ecept once manyfacrured by via
Old 06-28-2009, 09:28 PM   #45
jpinkerton's Avatar
Right now just USB Bluetooth and USB touchscreen.
I did have GPS plugged into it once, but haven't done it with USB touchscreen at same time. Should be finalizing install this week, I'll have a USB hub in the car and will let you know how the USB holds up.
Now keep in mind, I don't have the ION board, it's a few steps below that one, the 630i WiFi.
MSI Fuzzy 945GM1 MB dead? Jistari General Hardware Discussion 8 08-20-2008 04:40 AM
WTTF Nice momentary switches/Rocker switches CavityCr33p Classified Archive 1 04-14-2005 01:44 AM
Looking for a really nice small toggle. kiltjim General Hardware Discussion 4 04-02-2005 12:05 AM
FS Lilliput 7" faceplate fabbed into Saturn ION dash brandon Classified Archive 2 08-24-2004 10:51 PM
FS: MB Quart Seperates and Rear Deck Fills Krystos Classified Archive 0 01-09-2004 09:34 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
