I just installed my new carputer last wednesday. Here are the specs on my new pc:
Intel D945GCLF Mini-ITX Motherboard with 1.6 Processor
M4-ATX 250W Intelligent DC-DC PSU
2gig mem
Toshiba 30gig laptop HD
Laptop DVD ROM
Lilli 7" screen
GPS receiver
7 Port USB Hub
Logitech Joystick
I built a pc to set inside my dash behind my lcd. All the software was installed and working fine. I used this system every day for about a month on my bench using a 12 volt power supply and it worked great. I installed the pc in my dash last wednesday. It worked great. The m4 would start the pc when I turned the key on, and would push the pc to hibernation when I turned the car off. I drove the car to work Thursday and Friday and everything worked like a charm. I didn't drive the car at all on Saturday. I went out Sunday morning and started my car. The lilli turned on as usual. The led's on my usb hub came on. The light on my dvd rom came on, but no picture on the screen.
I turned off the switch that supplies the acc line to the m4 but the pc wouldn't shut down. I pulled everything out of the dash, checked all the fuses and wires. Everything seemed fine. I took the case in the house and hooked the m4 to my 12v supply and my carputer to my kvm. Again, the pc turned on, but no video. The bios screen didn't come up or anything.
I removed the m4 from the case and used a desktop psu and tried again. Same results. I figured the mb was fried so I order a new one. I installed the new mb and installed in in my case on tuesday. I put the memory, hardrive, and m4 back in. I hooked the m4 to my 12v power supply and the pc to my kvm. Same results. I removed the m4 from the case and used a desktop psu and tried again. Same thing happens.
I assumed that the problem was the mb. However, now I think it might have been both the mb and m4 got fried. Does this sound likely? If so, how likely would it be that the memory and hd are non functional to?
What could have been the cause of the malfunction? My thought was heat. My old system was in the trunk. This was in the dash. Last Saturday got to about 85 degrees outside with full sun all day. I added two fans to the case just in case. When I get this up and running again, they will be powered by the acc line on my car. I had the m4 set to delay startup for 5 seconds. If I wire it this way, the fans should start running 5 seconds before the pc starts to boot.
I wouldn't think I am pushing the m4 too hard. I was only running laptop hard drive and dvd rom, and the lilli. I checked all the wires in the car and everything was clean.
Any thoughts or idea's would be greatly appreciated.
