Quote: Originally Posted by
rakess
Nice little setup there. I have had a great experience with MCS, they're quick to ship and quick with communication.
rakess
Should I get a solid state hard drive or will a regular hard drive do fine? My rides shouldn't be too moving but I was wondering if a regular drive would suffice.
Most people have no problems with the desktop drives in their cars, however you're going to want to also look at your temp extremes. Where I'm at the temps do get very cold (-20) and can get very hot (100+). Right now I'm planning a laptop drive, but if that fails I'll move to a SSD. Similar to strikeback, by the time I go to buy an SSD it should be fairly cheap in comparison.
rakess
Luckily for me the Celica has a double Din dash, so the next thing i would buy would be a lilliput double din 7 inch touchscreen:
http://store.mo-co-so.com/double-din...tor-p-182.html
Seeing everyone work with bondo and fiberglass is appealing, but I think this would make for a cleaner option, and can easily be taken out which is nice if I need to resell, would you think cutting out the dash and installing a 7 inch touchscreen would be better? I am going to go to a car yard and try to find a celica and tear out the dash, like that if I mess it up its not an issue.
You could also look to Nexson on these forums and see if he'd have the time/what he'd charge to fabricate a dash for you. You could pull the dash that comes with your Celica, and send the dash from the junkyard to Nexson. He does great work and could likely fabricate something for you at a reasonable price.
Then just store the dash that comes with the Celica and if you ever go to sell you can easily swap out the dashes and not have to worry.
rakess
Do I need an amp to power my speakers?? I would like to just power the speakers from the PC, and then I have a powered sub already (sub with amp built in) so I wouldn't need any extra power.
I honestly don't know the answer to this, what make/model is your sub with amp? You could try a live chat with the techs at Crutchfield.com and see if the sub w/ amp you have would work without a headunit in your Celica. I'm guessing it would, but hard to say 100%. If it doesn't or wouldn't they'll be able to recommend a decent amp for you.
rakess
Does anyone know what the "cable package" option is, I tried looking it up but found nothing.
E-mail MCS and see what that option is, like I said they're quick to respond.
rakess
Last question, When I buy this computer will I get the cable to plug in the power source??? Or do you think this comes just in the cable package?
You'll need to run fresh lines from the battery to the interior where you want to place your CarPC. You'll want to add up the AMP draw for your build,
then read this guide - it has a chart in it that shows you the gauge of wire/fuse you'll need. My build is going to pull about 40AMPs, and that's rounding up.
If you're not comfortable running the wires or drilling into your car (in the event you cannot find a predrilled hole to pull the cables through) most car audio shops will do this for a small fee. I found one locally that will charge about $60 to do the drilling/pulling of cable for me.
There is a lot of information on these forums. Sometimes the forum search doesn't work for me so I go to Google and do a search like:
Code:
What Gauge Wire site:mp3car.com
And I'll get more results. Also read through some of the items in the FAQ link in my signature, that'll help as well.
Have you found where you want to mount the computer? That was a tricky part for me.
Don't forget to take lots of pictures and detail your install in the Worklogs section!
