Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 05-26-2009, 08:38 AM   #1
martijnh is an unknown quantity at this point
Unhappy CAN-BUS monitoring
Hi,
I've bought the CAN2USB product, which supposedly would be able to monitor the CAN bus and output USB. However, owning an BMW E90 CLI (2009), I can't get the interface to work at all. All that happens when trying to read information is the car saying 'go to dealer' (icon)
Does anyone have any experience with the E90 CAN bus, monitoring, or any other information, like what message means what?
Thanks!
--Martijn.
martijnh is offline   Reply With Quote
Advertisement Sponsored links
Old 05-26-2009, 08:48 AM   #2
Crinos is an unknown quantity at this point
Hia martijnh, and welcome to the forum
Oh... BTW: Nice car I got your predecessor... E46 Touring
You do not want to connect to the CAN-BUS in BMWs... You want to connect to the IBUS wich is a BMW only bus. You could get an IBUS USB device from Reslers. http://www.reslers.de/
Via the IBUS you can controll pretty much everything in the car... Do a search here on the forums on "IBUS", and you'll se
Crinos is offline   Reply With Quote
Old 05-26-2009, 08:53 AM   #3
Hi Crinos,
Thanks for the quick reply! Are you quite sure the E90 still has an IBUS? I thought it was replaced with the CAN BUS?
Old 05-26-2009, 09:31 AM   #4
All BMW from mid 1999 have both CAN and I busses.
The CAN-BUS is used mainly by the engine, transmittion, ECU(s) and to some part.. the AC units, wich allso talk to the IBUS.
The CAN-BUS can be used togeather with CarSoft 6.5 or newer to read of error messages, resett those messages, and read/configure settings of the car... For instance, KEY FOB settings, and miscallenous settings like default volume on CD-player and Radio unit. Metric og general units and such.
The IBUS is the thing that let all components in the car talk togeather. Like lights, power windows, cd-changer, radio/head unit, and actually everything that is electrical and can be manipulated in your car
PS: Getting CarSoft to work with USB reader is a pain in the....... <- fill inn apropiate uncomfortable place!
Old 05-26-2009, 11:23 AM   #5
I'm sorry to say I'm still not convinced my BMW has an IBUS; even my Parrot carkit steering wheel control unit is called Multican and uses CAN-HI/CAN-LO to filter out steering wheel commands? (which is essentially what I want my CarPC to be able to do as well)
P.S.: I don't mean to be ungrateful for you help, just sure of the facts ;-)
Is there any documentation on this topic you know of? I have almost all E90 documentation (PDF) (of which I'm not sure they all still apply to the 2009 model) and regarding buses, there's no mention of I-BUS, only:
Group Bus System Data Rate Structure
Main D-Bus (Diagnostic Bus) 10.5/115 Kbit/s Linear, Single-Wire
Main K-CAN (Body Bus) 100 Kbit/s Linear, Two-Wire
Main PT-CAN (Powertrain-CAN) 500 Kbit/s Linear, Two-Wire
Main F-CAN (Chassis CAN) 500 Kbit/s Linear, Two-Wire
Main MOST 22.5 Mbit/s Ring, Fiber Optic
Sub K-Bus (Body Bus) 9.6 Kbit/s Linear, Single-Wire
Sub K-Bus (Protocol Body Bus) 9.6 Kbit/s Linear, Single-Wire
Sub LIN-Bus (Local Interconnect Network Bus) 9.6/19.2 Kbit/s Linear, Single-Wire
Sub BSD (Bit Serial Data Interface) 9.6 Kbit/s Linear, Single-Wire
Old 05-26-2009, 01:19 PM   #6
You are right, and I'm truly sorry for miss guiding you, or anyone else for that matters.
http://ibus.stuge.se/IBus_Compatible_Cars
Car models without IBus
BMW 1-series E81
BMW 3-series E21, E30, E36, E90 Last 2 production years of E36 had ibus-controlled CD changers.
BMW 5-series E12, E28, E34, E60 E60 ver. USA had ibus-controlled seat ocupation sensor, Last 2 production years of E34 had ibus-controlled CD changers.
BMW 6-series E63/E64
BMW 7-series E23, E32, E65/E66
BMW X5 E70
BMW X6 E71
BMW Senior Six E3
Retrieved from "http://ibus.stuge.se/IBus_Compatible_Cars"
Old 05-26-2009, 01:38 PM   #7
No problem, I appreciate the effort to help me out :-) I found a product (car2pc) which seems to provide the functionality I need (steeringwheel control from my CarPC through USB). I contacted the owner and they state the E90 2009 compatible product will be available in june 2009.. TBC
Old 05-26-2009, 02:23 PM   #8
I feel so unbelivable ashamed... hehe...
Hope it works out for you soon. Allwas fun to see others dedicated to BMW
I where in the planing of my own CarPC layout... but now I have been caught up in learning myself C# and in doing so, I'm currently building the sound/media engine for my own frontend using FMOD
Old 06-11-2009, 06:58 PM   #9
teo
teo is an unknown quantity at this point
So I intend on getting a bmw E65 2004 or 2005
I want to primarily use it for diagnosing the thing to find out the problems. And then to play around with it.
If there is no iBus on it, it will have a OBD-II interface right? How can I talk to the car? Or is there some other bmw propiretary bus?
Oh and this is my first post, i have been reading around for a few hours and there really is a lot of information circulating around here. Very glad to have found this site.
Teoman
teo is offline   Reply With Quote
Old 06-13-2009, 02:29 PM   #10
Saab9-5's Avatar
Saab9-5 is on a distinguished road
Regardless of whether it has iBus or CANBus, any car sold in the US after 1996 (and Europe after 2001) has an OBD-II interface. OBD-II is primarily for diagnostics. But you can't access everything on a car's internal network through the OBD-II interface so that's why there are other interfaces (CAN, iBus, GMLAN, MOST, etc.).
Saab9-5 is offline   Reply With Quote
Old 06-14-2009, 09:36 AM   #11
teo
Ok,
so what do i need to get as an extra? And i am under the impression that iBus and the others use CANBUS hardware except that the packet protocol etc is different, I may be ofcourse completely wrong.
So thats the difference, ones that can scan the entire cars every system are sold for 3500 euros, I think. It basically looks like the same box that has different cables for all the busses.
I am about to make the purchase of an ELM327 scanner. Is there anything wrong with bluetooth, like it being slow? Would it be a good start or would i get dissapointed?
There is this: at mp3car.com
http://store.mp3car.com/ElmScan_5_Bl..._p/com-069.htm
and this on ebay.
http://cgi.ebay.com/ebaymotors/BLUET...#ht_1521wt_897
Although they look like the same thing, and i think they are the same thing I would like to pruchase the mp3car one {as i am getting usefull info from this site} but the 120 usd extra price makes it a bit inhibitive.
Ofcourse then I wont be able to use the scanmaster tool
http://store.mp3car.com/ScanMaster_O..._p/sof-scm.htm
which i might be able to live without.
Teoman
Old 06-15-2009, 09:25 AM   #12
DeltaFX's Avatar
DeltaFX is on a distinguished road
Don't forget to mention the evil VAN-bus
Shame on you peugeot !
Now Galileo is real. Muhahahahaha :p
DeltaFX is offline   Reply With Quote
Old 06-30-2009, 09:51 AM   #13
HighVoltage is an unknown quantity at this point
I asked around here quite awhile ago about the E9x KCAN and other CANbus networks but there didnt seem to be any knowledge base here on mp3Car. I started an in depth discussion here:
http://www.e90post.com/forums/showth...ghlight=canbus
HighVoltage is offline   Reply With Quote
Tags
bmw, can bus, e90, e90 cli, monitoring
Monitoring and ICE IrishBoy1986 Newbie 1 07-02-2007 03:05 PM
Can Bus Information _MARIO_ Engine Management, OBD-II, Engine Diagnostics, etc. 22 05-03-2007 10:44 PM
Need help decoding a one wire databus... Dexter Hardware Development 23 03-04-2006 09:09 PM
Our skin, 1024x768 -> A 1987 model Scania Bus Knutti MediaCar 0 04-27-2005 11:27 PM
