Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 03-13-2003, 12:44 AM   #1
ares
directly wiring sound into stereo... anyone REALLY good?
I have a shop manual for my car, which includes wiring schematics for the whole stereo, by looking at them, could anyone come up with a way to tap into it other than an FM modulator or tape deck thing?
if it makes it easier, its a Bose sound unit, with a seperate amp, and a second subwoofer amp. woud the line going from the head to the first amp, would that have R/L lines that I could just splice into with the sound card outs? then hook them both into a switch and just alternate between which input it plays? possible or no?
I can send pictures of the schematics if that will help someone to help me, but I have no where to host them so itd have to be by email or aol IM...
ares is offline   Reply With Quote
Old 03-13-2003, 12:46 AM   #2
I'm sorry, and you are....?
frodobaggins's Avatar
frodobaggins will become famous soon enoughfrodobaggins will become famous soon enough
possible, only one way to find out..
[H]4 Life
I'm a lesbian too.
I am for hire!
frodobaggins is offline   Reply With Quote
Old 03-13-2003, 12:57 AM   #3
ares
trying to make sense of it... and this is what Ive found, theres inputs into the head unit which it calls "navi input (-)" and "navi input (+)" and on the actual line it says W/B and L/B, there is also a "navi ground" along with a "navi on" they are 4 plugs on the back.
any way this can happen with these?
then going to the amp, it has 2 lines (+ and -) for each of the speakers... which totals to 4 pairs of wires(2 pair for front speakers, which after the amp split to control door speakers and tweeters, and the other 2pairs do the rear speakers) for a total of 6 speakers. plus anothe 2 for the subwoofer...
to me, the uninformed, it would seem there is no good place to splice into it after the headunit...
Old 03-13-2003, 02:54 AM   #4
Raw Wave
Rob Withey's Avatar
Rob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to beholdRob Withey is a splendid one to behold
Feel free to mail them my way and I'll take a look (rob_withey@hotmail.com). I hacked into my headunit a while back with no schematics to add an aux in. Details on my site.
Rob
Systems retired due to new car
Rob Withey is offline   Reply With Quote
Old 03-13-2003, 10:01 AM   #5
claylong
I am currently working on the same concept. The only difference is that I intend to remove my head unit compeltely, and drive the amp with the soundcard alone. It can be done, but it has gotten a little out of hand for my case. Let me fill you in.
First, I never had any diagrams or schematics of the radio, so I was working blind. The car is a chrysler, so the sound system is an Infinity system. It includes a headunit (HU), with 4 pairs running to an amp in the trunk, which then drives 6 or 8 speakers (can remember, but it does not matter). Again, i was going to remove the headunit, and drive the amp with the sound card.
What you need to be aware of, are signal levels. For example, the signal 'power' or 'level' coming out of a headphone jack, or in this case, a sound card spkr out, is called Line Level. This is just about the lowest power signal we are going to deal with. It will not drive speakers, but it is good for headphones and power amps. There are other power levels between the two, but the higher is the levels is 'speaker level'. The speaker level signal has a lot of power behind it, enough to driver your speakers. A higher power speaker signal, the better your speakers are going to sound (just b/c of the was the signal will clip or distort if you do not have enough power.)
USUALLY, what happens, is you have a car radio that has a line level signal running around inside the radio, and before it gets sent to the speakers (a setup w/o amps) it get amplified INSIDE the HU, and sent to the speakers. The amp in the HU is usually lower power, and that's usually why the stock HU's are not so great. The other option for NORMAL setups, is the line level signal in the HU gets mixxed (cd, tape, or radio source selection, then some tone controls and volume) and that LINE LEVEL signal gets sent to the amps. The amp then does it's job of amplifying the LINE LEVEL to SPEAKER LEVEL... Using gain controls, you can ususally get the level's just right, then use the volume control in your computer to adjust the volume (there are other options).
Now for the trick. If found that my system does not fall under either of the two catagories above. First, the amp does exist, so the amplification is not happening in the HU. The first test i preformed was to plug a line level signal (computer) into the INs of the amp in the trunk. SUCCESS!! Kinda. The sound was coming out of the speakers, but it was very quiet. After some more tests and many visits with the ociliscope, i found that the signal from the HU to the amp (the one i was expecting to be line level) was actaully higher power, higher amplitude than a line level.
I opened the head unit, and found a small 4 channel, 18w x 4 amp board. This means the signal was amplified some in the HU, then the rest of the way in the amp in the trunk.
Therefore, depending on your setup, it might be easier to modify your headunit. I found that my headunit had a six wire plug labeled "RF- GND - LF - RR - GND - LR". That was the line level signals going into the amp portion of the board. If i wanted to mod my HU, i would splice my computer signal into that plug. Volume control and everything would then be controlled throught the HU, and the computer audio would be ALWAYS ON, and mixed with the current HU selection. (Listening to a CD from my HU, and directions from my GPS).
I hope this helps. I would be glad to assist you in your decision and other questions.
Clay
^^^^ Wow, longest post yet....
System in the works:
Celeron 850 or PIII 933, SB Live! Value into a stock 4 channel amp, ATI vid, 10.4" sharp LCD w/ allen's controller, Elo SW touchscreen overlay and controller, GPS, TV tuner, FW DVD drive, 4 port serial card, and some other stuff....
Loads of ideas.
claylong is offline   Reply With Quote
Old 03-13-2003, 10:16 AM   #6
ares
wow... that is awesome...
ok, so assuming I figure out if I have an amp in the head unit, a few more questions.
how do I get a line level out from the computer? ussually computers have 2 outputs in the form of plugs that go to the speakers... how do you get line level from that.
than inside the head unit, you could cut the wires, and extend them outside the unit, plug those wires into a switch, and then plug the computer wires also into the switch, and run the output of the switch to the in side of the amp on the wire you origonlly cut. cause I want to keep my radio, but would like to be able to swap my input source, maybe I could even find a switch that would give me the option of mixing them too...
Old 03-13-2003, 10:41 AM   #7
albysure's Avatar
albysure
if you really want to do it right check out this:
http://www.davidnavone.com/adaptor_products.htm
this guy makes everything. you can even call or email him with your questions. he is a moderator on here:
http://www.carsound.com/ubb/ultimatebb.php
he will answer you quick. i use one of his delays to turn on my amps after the computer has booted to avoid the computer turn-on thump.
98% complete. Couple of tweaks to the fabrication.
http://www.cardomain.com/ride/212327/14
albysure is offline   Reply With Quote
Old 03-13-2003, 12:01 PM   #8
claylong
The speaker out on your sound card should be the line level outputs. It should be one stereo jack, that has both Right and Left channels in it. Assuming you do not have jumpers on your soundcard that allow you to switch between line level out and speaker level out, it should be line level.
As for the HU mod, you can do it however you like. Although, you should go through the process of testing and such (to make sure that you can succesfully get your signal spliced and amped), THEN make cuts.
IF you can get into your headunit w/o problems, and IF you can find the line level wires somewhere, you then need to try it with your computer signal. Just for safety of your computer, I would try it with another device's Headphone out. Like a small handheld radio or somthing... just in case...
I did not know about the David Navone guy, but it looks like I could have used him when I was searching and asking about line drivers. Oh well.
Loads of ideas.
Old 03-13-2003, 12:25 PM   #9
ares
any good way to get lines out of the card? like you have the 2 outs, but they are plugs, how do you get leads for them? buy 2 cables and cut them open?
or is that what those adaptors do?
I kinda assume the wires connecting line level to the small amp would have a plug I can just pull off and stick wires into the slots for testing purposes?
you say not to use the computer cause it could damage it, could it damage the head unit too? if so Im not sure Id be willing to take that risk...
Old 03-13-2003, 12:32 PM   #10
MP3DUB's Avatar
MP3DUB is on a distinguished road
2 Outs? You mean front and rear outs? Depending on what your head unit sends your amp (ie whether it sends four channels or two) it will dictate whether you can use your rear channels on the sound card, otherwise, you just have to worry about the front. And really, unless you're going to be listening to 5.1 Audio DVD's, the rear channels aren't of much use.
-Nick
_____________________________
Monthly MP3Car Chicago Meets
www.mp3vw.com Last updated: 07/07/2008
MP3DUB is offline   Reply With Quote
Old 03-13-2003, 12:39 PM   #11
ares
well I will be watching dvd movies... so the sourround owuld be nice.
and the head unit sends 4 leads out to the amp(FR, FL, RR, RL)... so does that mean there would be 4 leads from stereo to the internal amp?
Old 03-13-2003, 02:12 PM   #12
claylong
Yeah, if you have a 4 channel sound card, it would be 4 channels from snd crd to HU. (It would be 6 wires... 4 signals and probably 2 grounds, depends on what wires you use.)
Also, are you assuming that you have the amp in your HU? Depending on your model (what kind of car is it, anyway), and the stereo, it may not have an internal preamp afterall. In any case, you will PROBABLY have 4 channels inside the HU somewhere, preamp or not. You should be able to splice into them. The only things you need to worry about when trying to find the best 'place' t splice into, is where your volume control is done, and if you have the preamp. For efficency, i would guess the order would be as follows...
Source Mixer (CD, tape, @ line level) ------(4 channel)-----> Volume control (probably a digital pot, still @ line level) -----(4chan)------> Preamp (if it exists, @ preamp level) ------(4chan----> Out to power amp.
I would say the best place to splice in would be after the mixer and before the volume control.
Again, it's very very dependent on YOUR HU. You need to get comfortable with opening the unit and looking around... you will probably need to do it more than once if you are trying to install the system while keeping everything else working meanwhile.... (it's like trying to replace the tube of a TV w/o ever turning it off)
Look at what you have, and it may just be as easy as splicing in at the power amp. B/c my amp and computer are in the trunk, i am opting to reduce the possibility of noise by running the signal from the computer directly into the amp (with some amplification from a custom circuit... we will see about that...). Just a thought, and you should still be able to use your HU.
Loads of ideas.
Old 03-13-2003, 04:31 PM   #13
ares
its a bose stereo in a 350Z. not sure bout too much more than that. the service manual give full wiring diagrams on how its wired but does not go into depth about the INSIDE of the units, only the wiring between them. I guess if there was a problem inside, theyd yank the system out and send it off to bose and let them use their own service manual.
Old 12-30-2003, 04:39 PM   #14
RX7FDTT's Avatar
RX7FDTT is on a distinguished road
This is kind of what I'm concidering doing, the thing with the bose stuff is it's line level untill it gets to the special bose amps, and for the RX-7 needs a filter from a conventional radio to bring the levels back down.
There are a bunch of manufacturers (Sony beeing one) that make Line Out Headunits, that need an amp inline to drive speakers... I'd say, if you have the money, tear out the amps, and hook into them from the sound card... since an amp is usually expecting to amplify a line level or a speaker level.... other than that a small EQ or something else that accepts line and outputs speaker is what you want...
and BTW, Mic Level sound is even lower on the totem pole than line levels
Just for reference when trying to hook up the mic for voice recognition.... if you put it into a aux in on the sound card you'll get nothing but wispers... while if you take a line level out of sat a radio D-100 and stick it into the Mic In, be prepared to be blasted... unless you tell the D-100 that that's what you're doing....
I'm suprised no-one has found a good 2 channel or 4 channel amp that works with the line level outputs....
Sorry the main reason for this is that the whole idea is to replace the factory stereo with something "Better" and not take up any more room, and not sacrifice any features of the factory radio.... so leaving the factory radio in and splicing into it is not an option due to room, and uselessness issues...
RX7FDTT is offline   Reply With Quote
Old 12-30-2003, 05:37 PM   #15
MikeH is on a distinguished road
RX7
This one is $24 at WalMart....Has both line level and RCA inputs with volume control...
MikeH
MikeH is offline   Reply With Quote
