Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-09-2009, 07:29 PM   #1
chris350's Avatar
chris350 is an unknown quantity at this point
pico itx question
ok, so im still working on my set up and I have a pico itx system. Now i've seen that the pico can do 4 channel audio output as well as 5.1 or more..I would like to know where can i get the cables to get at least 4 channel audio. cause everything on a pico board is connected by pin headers. I got the manual and understand it somewhat, but where do I get the pin header cables, its an aritgo kit thats doing 2 channel sounds now
so my two questions are
Where do i get that pin header cable?
and
is it worth to do 4 channel audio or just split the two channels into 4 cause im am going to use an amplified system set up.?
CarPc
Project "Driver"
Planning [99.9%]
Parts Collected [98.5%]
Installation & Fabrication [98%]
Total Completion Level [96.9 %]
http://www.mp3car.com/vbulletin/work...ct-driver.html
chris350 is offline   Reply With Quote
Old 06-28-2009, 07:26 PM   #2
tempgp's Avatar
tempgp is an unknown quantity at this point
on VIA Arena site they have kit with enclosure and it has all calbes you need for extra $200, or otherwise go to Mouser Electronix and get yourself 3mm pin connectors ( i think thats 3 mm)
as to aydio thats all depand on ur amp
if ur amp is 2 channels thaen u need stereo source if its 4 ch thehn u do w/ 4 sources
Road Camera HD - Backup Camera Plugin + Mobile DVR BlackBox [Completed]
Bluetooth Cell Phone CallerID [Pre-Alpha]
Custom Button Bash Board - Add physical touchable buttons to your CarPC Project
Centrafuse Garmin Mobile PC Skin - GMPC Rebellium Skin
tempgp is offline   Reply With Quote
Old 06-28-2009, 08:12 PM   #3
chris350's Avatar
Thanks. I will check both out. My amp is a 4 channel amp.
CarPc
Project "Driver"
Planning [99.9%]
Old 06-28-2009, 09:16 PM   #4
tempgp's Avatar
then go w/ 4 ch
also ast to pins just take a ruler and measure the distance between pins and thats tipe of connector u need.
Old 07-02-2009, 06:43 PM   #5
chris350's Avatar
thanks. I will have to check the pins. does anyone know what the difference is when connection the cables? which is ground..AGN or the other one?
CarPc
Project "Driver"
Planning [99.9%]
Old 07-02-2009, 06:59 PM   #6
tempgp's Avatar
whats your model #?
You can go to Via Arena site and find all info about your board
Old 07-02-2009, 07:33 PM   #7
chris350's Avatar
its the pico itx 10000...the 1GHZ version.
i have the manual that describes all of it. but there is two grounds that i can see...one is AGND and the other is just GND
CarPc
Project "Driver"
Planning [99.9%]
Old 07-02-2009, 07:46 PM   #8
tempgp's Avatar
i cant find that model under pico
but for 700 model here is a linnk, u need User Manual - Pin Assigment document
http://www.via.com.tw/en/products/em..._id=690&tabs=1
Old 07-02-2009, 10:23 PM   #9
chris350's Avatar
that one:
http://www.via.com.tw/en/products/em...erboard_id=472
CarPc
Project "Driver"
Planning [99.9%]
Old 07-02-2009, 11:27 PM   #10
tempgp's Avatar
ok on the page u have me click downloads and at the bottom u will se User Manual, go to page #23. There us a pinout for your Audio and manual is self explanatory. If u use 4ch then u use Line out L/R connected to GRD and Suround L/R each connected to ground
u may also want to use ferrite rig to reduce noice is you are not using spdif
Old 09-30-2009, 08:35 AM   #11
RevheadKev is an unknown quantity at this point
@chris350
How did you go ?
I'm doing a pico system now with dual 2-channel amps (Front L/R + Rear L/R) and also wanting to find header cables for the 4-channel output.
I'll actually configure the system for 5.1 so I will have the sub channel ready for later.
My understanding is that the AGND is used for the audio channels and the GND is used for the spdif.
Obtained: VIA Pico ITX, M2-ATX clone, 7" Seform 800x480 LCD Touchscreen, Dual 2x75WRMS Mini Amps, IDE to Dual CF adapter, 4GB CF (Sys), ELMscan5-USB, GPS Mouse, Slot-load DVD
To get: 16GB CF (MP3s), Navigation software
Status: Starting Double-DIN build
RevheadKev is offline   Reply With Quote
Old 09-30-2009, 10:01 AM   #12
theonlykid is on a distinguished road
The correct socket pitch for VIA Nano/Pico boards is 2mm not 3. Standard headers are 2.54mm
theonlykid is offline   Reply With Quote
Old 09-30-2009, 10:35 AM   #13
Thanks, already know that.
What I am trying to find is any ready-made header cables for the 16pin audio connector.
I can get the separate plug and crimped cores, but they are industrial quantities, not singles.
Old 09-30-2009, 11:09 AM   #14
tempgp's Avatar
out of my memory go to viaarea website, go to pico section then somweher is the link on redistributor who sales casings, they also have all type of premade cables
Any in-dash monitor with built in FM Radio QUESTION. ??? 74Camaro LCD/Display 2 05-02-2006 06:15 PM
Forum Etiquette Enforcer Newbie 5 01-09-2006 06:58 PM
Paint And Polish Question gboy Fabrication 8 08-13-2005 08:22 PM
FM Card Question.... Superbike1k Car Audio 1 05-16-2005 10:03 AM
Cases for ITX xanimal General Hardware Discussion 1 02-17-2003 04:43 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
