Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 06-13-2009, 01:20 PM   #1
Lele78c is an unknown quantity at this point
WINTV-HVR-900H driver problem
Hi, i have a carputer with epia ml10000 and tinyxp, when i try to install Hvr-900h windows write "windows cannot load the device driver for this hardware. the driver may be corrupted or missing" and the board not work.
Any suggest???
thanks
Lele78c is offline   Reply With Quote
Old 06-13-2009, 01:22 PM   #2
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
lots of things get lost with tinyxp. Try it on a full install of XP. If it works then you know where the problem is.
Old 06-13-2009, 01:37 PM   #3
Yes thanks, i have just board in an other pc with full xp and it work, do you know if it's possible to add any plugin or update to tinyxp for work tv tuner?
I wouldn't change os because i have only 256Mb of ram.
thanks
Old 07-02-2009, 02:42 PM   #4
I have format my pc and install windows xp pro.
Now the HVR-900H work but the video is slowly.
I use dvbviewer with nvidia purevideo codec
The cpu stay at 80%
Audio is good and video is slowly.
Any idea?
Touchscreen driver install problem, HELP! (Lilliput 7") davem LCD/Display 4 07-04-2007 07:07 PM
Lilliput Touchscreen Driver Problem. gleinz LCD/Display 2 01-12-2007 12:30 AM
Touchscreen Driver Problem bry21317 Input Devices 3 05-27-2005 06:12 AM
MS S&T 2005 GPS receiver driver install problem... rdc_3200 GPS 4 01-01-2005 05:19 PM
Xenarc TS driver problem Sunglassesron LCD/Display 0 05-14-2004 03:52 AM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
