Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-02-2009, 09:41 AM   #1
Davefocus's Avatar
Davefocus is on a distinguished road
Voom Case 2nd HDD
Afternoon,
I've read that the Voom PC enclosure (Ampie) will accommodate two HDDs. I'm considering using a 2nd HDD or SSD and wondered whether anyone has any pics of two HDDs fitted?
I received some fitting rails with the Voom PC enclosure but couldn't see the information in the instructions......
Many thanks,
Dave
Vauxhall Astra SXi Car PC installed.
Centre console screen fabrication in progress.
Davefocus is offline   Reply With Quote
Old 07-03-2009, 05:30 PM   #2
Davefocus's Avatar
Curious for pics, anyone done this?
Thanks,
Dave
Old 07-12-2009, 03:18 AM   #3
Davefocus's Avatar
This is also known as a MoSoCo case aswell. Anyone with pics???
Dave
Old 07-18-2009, 09:36 AM   #4
Davefocus's Avatar
Bumpity Bump!
Dave
Old 07-18-2009, 10:28 AM   #5
nobb will become famous soon enoughnobb will become famous soon enough
Also interested to know since I am looking to do this in the future when I add an SSD as a boot drive. It should be similar to my MoCoSo case. I believe there is a simple metal bracket that just puts one hard drive on top of the other, with a bit of spacing in between. Ive seen another user with this setup, but dont see where you buy it.
You might also be able to just fabricate it yourself with two larger rectangular sheets of metal (one for each side). Or just use 4 thinner metal strips, one for each mounting hole in the hdd. Here is a quick mspaint of my idea. The dots in red are where the holes would be to secure the two hdd to the bottom plate of the case.
nobb is offline   Reply With Quote
Old 07-18-2009, 11:28 AM   #6
Davefocus's Avatar
Cheers nobb,
I've got the fitting rails but didn't know where to use them. I didn't think about on top of the first HDD, although that seems the most obviuos now you mentioned it. I'm surprised it's not in the manual at all.
I'll post the pic if I track it down or when I do mine!
Cheers,
Dave
Old 07-18-2009, 11:35 AM   #7
Awesome, looking forward to the pics, it would be helpful. Unfortunately, my MoCoSo case did not come with any sort of railings, so I am going to have to improvise something for my hdd mount.
Old 07-18-2009, 11:52 AM   #8
Davefocus's Avatar
Food for thought and possibly the thread you mentioned here.
Dave
Old 07-19-2009, 03:26 PM   #9
Davefocus's Avatar
First of all, apologies.....The MoSoCo case is similar but by no means the same. I still can't find any pics of the VoomPC (Ampie) case as yet. The search conitinues.........
Dave
Old 07-19-2009, 03:38 PM   #10
Davefocus's Avatar
Just found this on the Mini-box Knowledgebase, if anyone else is interested..
Quote:
Question
I would like to know if it is possible to fit two 2.5" laptop hard drives and a VIA EPIA MII-12000 using the M2 DC/DC power converter and the ATX extender board (all of which you sell) entirely inside the enclosure.
Solution
You have a set of brackets for the 2nd laptop HDD, that is mounted on top of the extusion (inside) in between the two ribs.
Dave
Physically wiring a screen from a Voom case djjon General Hardware Discussion 2 04-25-2009 03:12 PM
M2-ATX and Epia CN13000 in a Voom case...No power polo6979 General Hardware Discussion 8 11-27-2008 05:02 PM
WTB: m1atx and ampie case and laptop hdd EsKALad Classified Archive 8 11-19-2005 10:41 AM
FS: Brand New Voom Case $65 dexy Classified Archive 11 10-29-2005 03:51 PM
FS:60 laptop slim hdd w/ external usb 2.0 case e36mp3 Classified Archive 2 11-16-2004 04:05 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
