Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-09-2009, 09:50 AM   #1
HumungousBacon's Avatar
HumungousBacon can only hope to improve
Backup battery
Anybody ever use a UPS (uninterrupted power supply) to power their pc for a little while so it can update or sync without having to have the car running?
HumungousBacon is offline   Reply With Quote
Old 07-09-2009, 11:01 AM   #2
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of lightDarquePervert is a glorious beacon of light
They are big, heavy, and they don't like cheap inverters.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Old 07-10-2009, 12:01 AM   #3
Old 07-10-2009, 03:16 AM   #4
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Quote: Originally Posted by HumungousBacon View Post
why do you need a
What DP said is exactly true...
I read a while back someone was using some serial connection to a PIC they programmed and a spare battery on a tank circuit.
Old 07-10-2009, 03:19 AM   #5
nalav's Avatar
nalav is on a distinguished road
I'm not understanding why an UPS is needed, would the car battery not suffice?
nalav is offline   Reply With Quote
Old 07-10-2009, 03:32 AM   #6
Crinos is an unknown quantity at this point
That is my thoughts as well... What is an UPC??? A battery of course!
And bumping a post from yesterday is just plain rude!
Crinos is offline   Reply With Quote
Old 07-10-2009, 05:30 AM   #7
North of the land of Hey Huns
malcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to allmalcom2073 is a name known to all
As DP said, most UPS's don't like cheap inverters. We use Xantrex Pro Sine inverters at work because they play nice with UPS's, but they cost upwards of $1500. The key thing to look for is "true sine wave" inverters that put out a clean sine wave, UPS's are very finicky about their power input.
RevFE - Try it, you just might like it.
Carbon - Next Generation Touchscreen Browser
Come join us on IRC: irc.efnet.net #mp3car
Audiophiles make me chuckle as they pad my wallet.
malcom2073 is offline   Reply With Quote
Old 07-10-2009, 06:11 AM   #8
A UPC is a barcode issued by a product's manufacturer for inventory control.
A UPS (uninterruptable power supply) is a battery.
QFT!
Old 07-10-2009, 03:46 PM   #9
Just a simple question. didn't know all of that. i just don't want to leave my car running while i sync it with my home PC. was trying to figure out a way to power the PC without draining the car's battery.
Old 07-10-2009, 04:07 PM   #10
2k1Toaster's Avatar
Well you will be draining a battery no matter what.
If you are planning on using it for long periods with the car off, I suggest a secondary battery system consisting of a deep cycle battery (can be discharged and charged to death lots of times without loosing much charge as compared to your standard lead acid which will never be the same after a deep discharge), a charging system that isolates the secondary battery from the car starting battery when off, and charges when on, and a smart DC-DC PSU for the PC.
Old 07-10-2009, 06:58 PM   #11
rsrblade is an unknown quantity at this point
Adding my 2 cents I purchased a second wire harness and attached it to a PC power supply I had laying around. When I need to make large updates, tweaks, transfer songs, etc I run out an extension cord. Granted, the audio doesn't work as my amp isn't powered up but ... you get the picture.
rsrblade is offline   Reply With Quote
Old 07-10-2009, 09:58 PM   #12
stevey500 is an unknown quantity at this point
Just install another battery in the car. I have a 12v 7ah sealed battery under the hood. I have a relay between the main battery and it. If the key is off, the relay is off, that disconnects the main battery from the sound and computer system. If its left on or trickles dead, turn the key on, power is back, backup battery recharges.
Multiple relays or a large relay will be required for heavy duty audio/computer systems over 30ah of draw.
Age: 18 | Car: Isuzu Rodeo 01 | http://www.mp3car.com/vbulletin/show...s-eee-box.html
stevey500 is offline   Reply With Quote
Old 07-11-2009, 12:03 AM   #13
nalav's Avatar
It's possible to specify that the pc should shut down in xx minutes or something of the sort. You could possibly use this to leave it running long enough to sync.
Old 07-11-2009, 12:53 AM   #14
wow really negative rep wonderful guys thanks for the warm welcome.
Battery Loosing Charge TeamRSX Power Supplies 15 05-15-2008 11:26 AM
Powering car from a 13.8V power supply ok? PURDooM Power Supplies 27 06-12-2006 12:56 PM
2nd battery + computer controlled lighting jparks27 Show off your project 22 06-02-2006 09:52 PM
FS on Ebay 12VDC 5.1Ah Ignition Backup Battery TheSpecialist Classified Archive 111 03-24-2005 09:32 PM
MPJA - MECI ASTEC DC-DC Converter Luc General Hardware Discussion 39 11-22-2004 10:31 PM
