Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 07-30-2009, 02:49 AM   #1
Punky is on a distinguished road
Intel D945GCLF2 Killer
I thought I'd share this with everyone. Like most of you the mini itx boards has been a long wanted upgrade for me, but from reading around the Intel D945GCLF2 is the cheapest but also the buggiest. I went and buy a D945GCLF2 anyway to see if i could make it work, it works, but the BIOS just takes too long to boot. So i ended up using it for our video surveillance system. Other boards like the zotac are too expensive for my taste, and not enough information about how good they are as a carpc available.
So i finally found one that met all of my requirements: dual core atom, cheap, mini itx, quiet. From searching on newegg, i found: http://www.newegg.com/Product/Produc...82E16856119012
for 130 you get mobo, cpu, case, and psu! and best of all its a foxconn mobo which means that it has quickboot! Well after waiting for two weeks, it finally arrived, and it took me a whole day to replace it with my existing system.
Here are my thoughts about it:
- Boot is hella fast! around 17sec resumes!
- dual core atom is plenty fast
- low heat
- really quiet fan
- nice quality built
- no ion though, which i don't feel is necessary for car anyway.
- though the mobo is mini itx, the case is quite large, which takes a bit more space in the trunk than i would like.
bottom line: if you have the same requirements as me, get this instead of the intel version, even if you strip off the large case, its still very affordable.
Punky is offline   Reply With Quote
Old 07-30-2009, 01:13 PM   #2
nobb will become famous soon enoughnobb will become famous soon enough
O man that is nice, I cant believe I paid $200 for my Jetway board a while back. Performance wise, does anyone know how a dual core 330 atom compares to a single core 2.0 ghz Via C7?
Can you clarify what you mean by Foxconn's quickboot? How is that different from any other manufacturer that also has the quickboot setting in the bios?
nobb is offline   Reply With Quote
Old 07-30-2009, 03:07 PM   #3
i don't think they're much different, its just foxconn always has quickboot in every motherboard, that's what i'm trying to say. Just using it for centrafuse and gps, I don't see much of performance difference between my 2.4 P4 and this dual core atom. I bought this board was because it has sata, so i can finally upgrade to SSD.
Old 07-30-2009, 07:20 PM   #4
insaneramman's Avatar
insaneramman is an unknown quantity at this point
Thumbs up How big is it?
Looks like a good find. Any chance you could post some detailed measurements on the case. Would love to upgrade to this set-up. My set-up has serious size limits.
For those who fought FREEDOM has a flavor the PROTECTED will never know. Support our troops.
insaneramman is offline   Reply With Quote
Old 07-30-2009, 08:24 PM   #5
This is the entire system dimension: 282mm*95mm*315mm(with bezel)
The board itself is a mini itx board though, so if you take out the case and get a much smaller system.
Old 07-31-2009, 10:55 PM   #6
nst6563 is an unknown quantity at this point
that's not a bad deal at all with the psu and case. It looks like you'd still need an inverter to run that with the psu it comes with. Is that what you're doing? I don't think the case seems that big at all. The measurements they give it seems like it's about the same size as the travla case I've got only about twice as tall.
I upgraded mine a while back and also tried the intel atom 330 board. boot was slow as hell and it just didn't impress me in the least bit.
I ended up going with a $50 Zotac mini-itx and a 1.6Ghz Conroe-L based celeron. I think the total cost from newegg was about $75. From post to boot is (no resume) is about 12-14 seconds (using SSD with EWF). The nvidia chipset on the baord does run hot though, but even in the Houston heat I've not had a thermal issue with it.
nst6563 is offline   Reply With Quote
Old 07-31-2009, 11:10 PM   #7
Red face
Thanks Punky was hoping for inches I saw those dims on the site. My convert ruler is at work.
Old 07-31-2009, 11:54 PM   #8
11.1023622 x 3.74015748 x 12.4015748 inches
google my friend.
Old 08-01-2009, 10:05 AM   #9
Lol. When I saw the mm measurements (also listed on neweggs site) the first thing I compared them to was fan sizes
it's roughly 2x120mm + 1x80mm fans wide, 1x90mm fan high, and 3x120mm fans long.
Old 08-01-2009, 10:22 AM   #10
shortee611 is an unknown quantity at this point
Think of it this way 25mm is roughly a inch (actually 25.4mm = 1 inch) so a 100mm is roughly 4 inches.
shortee611 is offline   Reply With Quote
Old 08-01-2009, 01:16 PM   #11
Fusion Brain Creator
2k1Toaster's Avatar
2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future2k1Toaster has a brilliant future
Or you could just stop converting it and use metric like the rest of the world! It makes more sense logically and is more accurate anyways. That and it is based off of a stick of gold, how much cooler does it get.
Intel D945GCLF2 Dual-Core Atom txspazz General Hardware Discussion 653 Today 04:01 PM
Core Duo / Core 2 Duo Mini-ITX boards RedGTiVR6 General Hardware Discussion 149 08-14-2009 10:54 PM
Experiences with the Intel D945GCLF2 Motherboard and VoomPC2 case for Carputer/ CarPC analographi General MP3Car Discussion 11 07-04-2009 04:35 PM
Shuttle sv24 or fv24 michael_16j General Hardware Discussion 6 06-05-2006 03:56 PM
How is this motherboard? Intel board inside.. sspiro General Hardware Discussion 5 01-16-2005 02:16 PM
