Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 10-31-2009, 04:01 AM   #1
Davefocus's Avatar
Davefocus is on a distinguished road
Low profile SATA cable for Voom PC-2 case???
Morning all,
Does anyone 'know of' or 'has seen' a low profile SATA cable that would be ideal for a Voom PC-2 case. I thinking something similar to this
Image from http://www.cs-electronics.com/sas-cables.htm
for a WD Scorpio Blue SATA data and power lead. I've searched 'high and low' but haven't seen anything suitable. The problem being the ATX connector and D945GCLF2 RAM are all very colse in the Voom PC-2 case and the standard SATA data and power lead get a little squashed between the case and RAM.
Your help is appreciated as always.....
Vauxhall Astra SXi Car PC installed.
Centre console screen fabrication in progress.
Davefocus is offline   Reply With Quote
Old 10-31-2009, 07:15 AM   #2
mrbean_phillip is on a distinguished road
Yep, I use 2 of those multilane SFF8484 cables on my HP P800 SAS Raid controller - but there's enough channels in there to drive 4x dual-port SAS drives - the one end connects to the raid card, and the other end, in my case also SFF8484, to the HP 8-drive drive-cage.
I haven't seen anything similar for single SATA drives, except those various 90-deg angle Sata cables, you can find some examples over at Performance-PCS
Hope you find what you're looking for, also verify Sata1 vs SataII before ou buy.
mrbean_phillip is offline   Reply With Quote
PC Power Control Cable timekiller General Hardware Discussion 2 11-07-2007 05:08 PM
Low profile Vga Cable?? Lilliput Vga too big! biglips31 General Hardware Discussion 2 11-11-2004 11:28 PM
