Quote: Originally Posted by
justchat_1
I posted this in another thread but i'll post it here to-this really isn't as big of a problem as most people think. The elm and other chipsets are designed to run on 5v. Usb Bus power is 5v. For a few reasons though, most scanners use the constant battery line regulated to 5v instead of the 5v usb. I image the OBDPro does it the correct way.
There are a few easy fix options here:
1. Solder a jumper to the obdII chip and clip the vbatt line.
2. (EASY) Cut the VBatt line in your obdII connector (Vehicle Side) which is pin 16. Connect Acc power. Now your OBDII reader will only run when the car is running and prevents any battery drain conditions.
3. Get an OBDII extension cable and soldier in a switch to the vbatt wire.
Hi mate, some good options.
Option 1: As chunkyks said some people would be reluctant to open their $150 device and start messing around with it potentialy causing damage if done incorrectly.
Option 2: Modifying the car wiring can have implications with the warranty on the car.
Option 3: I think i would take the basis of idea 3 and modify it slightly. I would use a relay instead of a switch to make it automaticly turn on once the car is turned on.
Get an OBDII extension cable and hook up the power wire to the N/O (Normaly open) relay contact.
Take a switched 12v acc power and an earth/ground wire to the coil of the relay.
Every time the car is turned on the switched 12v would power the relay coil, causing the N/O contact to "Close" allowing power to pass to the OBDII device. When the ignition is turned off the power is lost from the relay coil dropping out the contact.
If anyone has any questions i'll be happy to help
Regards Michael
