Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-01-2000, 04:29 PM   #1
Post stock stereo
Does anyone have any ideas about how to connect to a stock stereo without using the cassette attachment. I thought about a FM trasnmitter but that would cause problems for others on the road. I was thinking that there has to be a way to hook into the antana input in the back of the stereo. Any ideas would we appreceated.
Thanks,
kyteman
kyteman is offline   Reply With Quote
Advertisement Sponsored links
Old 04-02-2000, 10:51 AM   #2
Post
The technique I use is really simple yet no one uses it. I have 4 amps in my car. My Stock stereo is connected to my E/q and my E/q to the amps. You can pick up and E/Q at Radioshack stick it into your system and use the line in on that to get input. You can make a volume control. Or just use the PC to control the volume.
ZyKlon X is offline   Reply With Quote
Old 04-02-2000, 01:40 PM   #3
Post
An FM Transmitter broadcasts an FM freq within a certain amount of feet. I wouldn't recommend one for your car. What you need is an FM Modulator. An FM Modulator is hard-wired directly to your antenna and broadcasts an FM signal just through your radio. DONT BUY A CHEAP ONE! A good FM Modulator will cost you anywhere from $80 - $120. Make sure you get a UNIVERSAL modulator.
Mp3Chevy is offline   Reply With Quote
Old 04-02-2000, 04:19 PM   #4
Post
Mp3Chevy do you know where to get a FM modulator that is not specific to a cd changer. Everything that I can find is cd changer specific, with no other inputs.
Old 04-02-2000, 05:39 PM   #5
Post
Actually, I found an awesome Accelle Universal FM Modulator on ebay for $76. As long as you can find one with rca input, and ISNT depending on the changer, you'll be ok
Old 04-04-2000, 04:48 PM   #6
Cool
I would think that the easiest thing would be to either go through a crossover or to use a 4-way amp (assuming you only have 4 speakers). Either way, you can just take the sound out from your computer, get some RCA converters, and you just plug it right into the amp or crossover. This is what I am planning to do, but have not tried it yet. The only issue I see is that your are going to have to split the inputs to the crossover/amp so that you can plug your car stereo in as well.
Dufass is offline   Reply With Quote
