Go Back   MP3Car.com > Mp3Car Technical Hardware > General Hardware Discussion
Old 02-20-2010, 08:15 AM   #1
0utlawza is an unknown quantity at this point
Talking powering Zotac ION N330 with M2-ATX
Hi Guys
I am trying to build my first carPC and have the following components:
Zotac ION N330 1.6 Atom motherboard
4GB Kingston RAM
M2-ATX power supply
VoomPC 2 case
HDD and DVD RAM drive
I have installed all the components onto the VoomPC 2 plate and am now trying to connect all the bits together. I dont seem to be able to understand how to power the motherboard from the M2. There is no 24 pin connector on the Zotac motherboard. I am able to run the power from the case to the M2-ATX.
I have searchid on Google and dont see to find any solution with my motherboard and the M2-ATX power supply.
If anyone has some insight it will be most appreciated.
TIA
T
0utlawza is offline   Reply With Quote
Advertisement Sponsored links
Old 02-20-2010, 09:14 AM   #2
rtgree01 is an unknown quantity at this point
Which Zotac Ion board did you get?
The Zotac Ion-A-U has a 19v input that you'd want to use one of the other power supplies.
The Zotac Ion-D-E has the ATX power connector that almost any ATX style power supply should be able to handle.
I'm not sure what the advantage of either are.... maybe somebody else will chime in....
Sorry.....
Ryan
rtgree01 is offline   Reply With Quote
Old 02-20-2010, 10:38 AM   #3
Raw Wave
soundman98's Avatar
soundman98 is a name known to allsoundman98 is a name known to allsoundman98 is a name known to allsoundman98 is a name known to allsoundman98 is a name known to allsoundman98 is a name known to all
from what i have read, the board with the 19v input is marketed as a super compact pc-- the 19 volt power adapter allows everything to be in a very small case, and the power supply can be located outside of the case.
if your board doesn't have a atx connector, then it will probably need a 19v power supply
crazy and insane are some of the other words used to describe really cool people. at least that's what the voices told me...
soundman98 is offline   Reply With Quote
Old 02-21-2010, 05:54 AM   #4
Thanks for the response guys
I do indeed have the Zotac Ion-A-U board that is fed by an external; 19V supply. I have however read that these boards can be powered by the M2-ATX. I was just wondering how that would be done. I am loath the purchase a DC-AC converter for the car and then run the board off the 19V supply. But looks like this might be the easiest solution. Will continue to scour the net to see if there is another solution out there.
Old 02-21-2010, 06:01 AM   #5
Neither darque nor pervert
DarquePervert's Avatar
DarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to allDarquePervert is a name known to all
You're not going to be able to power teh A-U variant with an M2ATX.
It doesn't put out 19v, plain and simple.
You don't want an inverter, and I can understand why.
Maybe look into a Carnetix.
This is another example of why planning your setup thoroughly is so important.
LOOKING FOR THE FAQ? IT'S HERE.
You never found that link, did you? Why? It's hard to find in the NavBar across the top of the forums, amongst a lot of other crap.
TELL MP3CAR YOU WANT A LINK TO THE FAQ IN A MORE OBVIOUS, NOTICABLE LOCATION HERE.
Hacking the Zotac ION tripzero LinuxICE 3 03-13-2010 10:51 PM
WTB 7" LCD, VoomPC2 and M2 ATX caenis Classifieds 2 11-15-2008 10:18 AM
Xbox w/ M2 ATX and PSU convertor MiniRX7 Power Supplies 1 11-25-2007 06:45 AM
powering a VIA MII w/ a ATX powersupply boostedGT-S Power Supplies 3 01-20-2005 12:57 PM
Powering a datalux screen from atx psu Speedpass101 Power Supplies 1 10-08-2004 03:19 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
