Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 05-12-2003, 08:28 PM   #1
allenruble's Avatar
This is a good wireless card cheap
This thing works good . Fits in your pci card slot and only 2" tall.
Here is the link
www.sounddomain.com/id/2000mp3ranger
Mp3 player - 10.4 Allbrite Gigabyte GA-71XEH , 700 mgz t-bird , coolmaster fan , 2x 128 ram + 1 512ram , ATI-RAEON RV100 ,on bd sound , Linksys Wireless-B usb network adapter , 20G IBM TRAVELSTAR
allenruble is offline   Reply With Quote
Old 05-13-2003, 05:31 AM   #2
Registered User
aoLhaTer's Avatar
heh, d-link isnt exactly "good" but yes, it should work
so so price
search pricewatch and there should be a few lower (if youre planning on buying from one of the companies make sure to do a resellerratings check first)
2004 G35 Coupe project
aoLhaTer is offline   Reply With Quote
Old 05-13-2003, 10:56 AM   #3
Registered User
I beg to differ, Dlink works well. I have used both. I am currently using dlink and have had no problems. Although I will say, the transfer rate is not as good as Linksys. That being said D-Link is easier to setup and secure. (The router that is.)
mhermann is offline   Reply With Quote
Old 05-13-2003, 02:53 PM   #4
The D-Link equipment (wireless cards) I have kick the *** off my Linksys cards. The access points are not quite as powerful as a hacked Linksys one though. Any way, a PCI card is not the best thing to use in a car.
Comp. Specs:Shuttle SS40G, Athlon XP 1700+, 256MB DDR, 40GB HD, Belkin Desktop 802.11b card (good range), SB 128 sound (onboard is a bit noisy), DVD ROM
Toshiba 100CS laptop, P75 40mb ram, 550MB HD, Megahertz LAN/modem PC card, modified to run off 12VDC
Other stuff:Generic USB hub & USB to serial adapters, BS2SX power control system w/battery buffer, Jazz 300W Inverter, FM Modulator, Palm Vx, & GPS
Status: 80% complete (Almost done with the controle boxes)
Sir_Pyro is offline   Reply With Quote
Old 05-13-2003, 02:58 PM   #5
Registered User
It depends how he is using it. I use mine just to transfer files when the car is in the garage. It works fine in that regard.
Old 05-13-2003, 09:10 PM   #6
bosstone74's Avatar
Quote:
What would be the "BEST" then? surely not USB
BossTone74
bosstone74 is offline   Reply With Quote
Old 05-14-2003, 01:46 AM   #7
Why not USB?
I recon the USB is the best choice when it comes down to wireless netowrking in the car.
If you carputer is under the sit or somewhere away from the window you not going to get much singnal coming out of the car...
With USB you can place the adaptor next to the window and run it to where ever your box is.
Fosgate
System Comp V3 - In progress.
Low power MB with C7 CPU, DC-DC PSU, car ECU link, USB TV, GPS, 7" TFT, Wireless, Voice.
Fosgate is offline   Reply With Quote
Old 05-14-2003, 04:57 AM   #8
jol
jol's Avatar
even cheaper:
http://froogle.google.com/froogle?q=...etween&btnP=Go
My cars
jol is offline   Reply With Quote
Old 05-21-2003, 01:24 AM   #9
vladilen's Avatar
Just tried this card - not sure if the design is bad or if I just got a bad one. Will not hold connection to my access point. Will not connect at all if there is another wireless device (phone or laptop) in the same room.
Plan to try a different brand.
vladilen is offline   Reply With Quote
