Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 04-23-2001, 10:07 AM   #1
GMpc
Talking Sony hu w/changer control input problem solved!
I have a sony head unit with cd changer controls. I have been looking for a input fix/solution and I came across another member's idea to use the changer audio input. That is possible only if there is a changer connected to the control port. So you play a cd in the changer and use the changer audio in as the computer input but this leaves the problem of having an almost useless changer. But I dont see any reason why you could plug the changer audio into the soundcard line in and mute it while using the computer. Even if you don't have a changer you should be able to pick one up on e-bay for around $40 instead of buying the sony input adapter for $100 . It was a good idea and it works great so far for me.
AMD K-6 @ 350 mhz
PCCHIPS Baby AT
onboard LAN/MODEM/VIDEO/SOUND
6" Sharp TFT
GMC Sierra '94 Ext. Cab
GMpc is offline   Reply With Quote
Advertisement Sponsored links
Old 03-13-2009, 09:18 PM   #2
tigust is an unknown quantity at this point
aux input control - sony HU
hello,
Do you think it would be possible to fool the sony HU in knowing the signal going out of the unilink cable on the XA-C30 aux adapter and reproduce it in a way or another ??
tigust is offline   Reply With Quote
