Did you connect them to the 12v rail from the psu in your pc? Or did you just wire it to the cars 12v line? If you did the last, wich line did you use? the remote? or just any 12v line?
I want to run cooling seing how I run a XP 1700, and it gets pretty damn hot here in South Florida. I do run the XP underclocked. Its only running at 1.1GHz but that is still pretty hi and it heats up pretty good. I have never had a restart, cause of heat issues. but heat is electronics number one enemy.
Any recommendations are welcomed.
