Was able to split the two parts of membrane, so that I could probe onto the pads inbetween, if you do this becarefull not to rip the rubber as there are tracks on it. You can then buzz out what tracks go to where, on the bottom connector, I got a friend to do it who is a soldering PRO.
You need to remove some of the keys to get the membrane to lift
Then with a bit of perciverence you can get the two halves of the membrane to split
Use a multimeter to buzz out then solder on the connector beneath.
