Go Back   MP3Car.com > Mp3Car Technical > General Hardware Discussion
Old 08-08-2003, 11:27 AM   #1
wi77iam's Avatar
wi77iam
EPIA M9000 connection to car amp
I want to connect my EPIA M9000 to a four channel amp in the car. One installer I talked to questioned whether the computer can output a high enough voltage to the amp through the Line Out. He said the amp should get about 0.5 to 3 volts in. I guess if the input to the amp is not high enough, the amp will be amplifying a lot of noise in addition to the signal. He said I might need a pre-amp. When I connect the computer to my home stereo system, it sounds just fine.
3 questions -
Does anyone know the voltage of the Line Out?
Do you think I need a pre-amp?
Is anyone connecting an EPIA Line Out to a car amp successfully?
Thanks.
wi77iam is offline   Reply With Quote
Old 08-08-2003, 12:11 PM   #2
Raw Wave
Confused's Avatar
Confused is on a distinguished road
I shall be doing this with my M10000 when i get it is delivered.
I'm hoping to be able to eliminate the HU all together for my CarPuter
I have successfully put another soundcard in a much older computer directly into the amp, but without any decent software or controller it wasn't too long before I hooked it directly into my HU again Not because it didn't work, but because for some reason the software i was using didn't remember the last volume setting!!
Garry
Co-Developer of A.I.M.E.E
www.aimee.cc
Confused is offline   Reply With Quote
Old 08-08-2003, 02:37 PM   #3
Raw Wave
Defiler's Avatar
Defiler is on a distinguished road
The Voltage is not enough for a good signal. Get a signal booster. And don't use the onboard sound...it sucks. It totaly lacks in mid and lows. I have the M-9000 and change my sound card for this exact reason...
Defiler is offline   Reply With Quote
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
