If you are just getting a line of 'shadow' at the top of the LCD and nothing at the bottom, it means that the LCD is powered correctly, but the software has not been able to initialise the driver chip.
Check the data pins are wired correctly and the two control pins for read/write and register select and also wired correctly.
Using Windows NT will also not work as it blocks direct access to the parallel port.
Also, beware, some peoples circuit diagrams are stating you need -5volts for the 16 X 2 display when this should read 0V or GND.
