Quote: Originally Posted by Brayden
Might be noob question here.. but for what?
for using as a case for your carputer.
if you use a heat pipe to cool your cpu and other components that need cooling, and connect the heat pipe to the case itself, then most of the heat will be disapated to the outside of the case, just like how an amp works.
amp cases are usually thick extruded aluminum with large heatsinks attached, so they offer protection as well. that way you can keep your computer in your trunk and not have to worry too much about it getting banged up.
